SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Honda K1 electrics
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Honda K1 electrics (Read 1387 times)
sweenerman
Full Member
Honda K1 electrics
on:
October 10, 2005, 07:48:31 AM »
Where do I start! K1 sitting outside [upstate NY] for 15+ yrs , Kicks over, installed new battery, new used coils. Turn key to on, get nothing, No spark no lights, nothing, Points are ok. What is my next move? Thanks sweenerman.
Logged
Jonesy
Shop Rat
Old Timer
"Damn! These HM300 Pipes Are Expensive!!!"
Re: Honda K1 electrics
Reply #1 on:
October 10, 2005, 07:52:51 AM »
First, try to obtain a wiring diagram for your bike to verify everything is as it should be interms of electrical layout. There are many posted online.
Take apart every wire connection, one at a time, clean them and reassemble with a small dab of dielectric grease. You'd be amazed at how much of the electrics can be woken up this way! Takes a few hours to do, but well worth it. Also install new fuses. I've seen ones that look OK, but didn't make continuity.
Good luck and let us know what you find.
Logged
Bob Wessner
"Carbs Suck!"
Really Old Timer ...
Reply #2 on:
October 10, 2005, 07:59:41 AM »
I agree with Dan. Mine sat for 22 years, same story. I cleaned and greased each an every connection and all electrics now work fine. Don't forget the rats nest in the headlight shell.
Logged
frostypuck
Enthusiast
Reply #3 on:
October 10, 2005, 08:23:53 AM »
I would start looking at the fuse. Your K1 should have but one Main fuse. Also check that the key switch is attached and correctly wired. Alot of people have moved the key switch from under the tank to the handlebars, and messed up the wiring.
With the battery installed and charged up, (you did charge the new battery,right?) you should be able to place something like a long screwdriver across the big terminal screws on the starter solenoid and get the starter to spin.
Chris in Boston
Logged
Boston, MA, USA
Clyde
Hot Shot
Reply #4 on:
October 11, 2005, 01:10:33 AM »
This site may help
http://oldmanhonda.com/MC/wiring750K1.html
Logged
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
sweenerman
Full Member
Reply #5 on:
October 12, 2005, 05:06:42 AM »
Thanks, Guys, I,ll start on checking all the connections . Thanks, Sween and iI will keep you posted
Logged
Bob Wessner
"Carbs Suck!"
Reply #6 on:
October 12, 2005, 05:29:47 AM »
Make sure you check 'ground' points/connections also, not just the bullet connectors. Good luck, let us know how it goes.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Honda K1 electrics
