Author Topic: reinstalling gas cap  (Read 5234 times)
Offline tlbranth
« on: February 17, 2009, 11:04:13 AM »
Don't know if this is a new idea or not but......When reinstalling the pins, an easy-ish way to peen the drilled end without chasing the pin all over the garage is to place the tank so the drilled end is upward, place a small steel ball on the drilled end, then squeeze the head of the pin to the ball with a pair of channelocks.
If the ball won't stay put, stick it there with a touch of vaseline.
« Last Edit: February 17, 2009, 11:17:19 AM by tlbranth »
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Johnie
Re: reinstalling gas cap
« Reply #1 on: February 17, 2009, 11:50:17 AM »
I used a C-clamp with tape holding a BB in place on the clamp.  I also protected the paint with some packaging wrap so the clamp would not scratch it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #2 on: June 10, 2012, 06:37:53 AM »
Ok that sounds like a great idea for re-flanging the pin. On the other side of the cap the PO had painted the tank without removing the lock,Phillips head and threads were painted tight. I rounded the Philips and had to remove the screw but it's ruined. Can replacement screws be had at a local hardware store? Preferably,but not necessarily Allen head?
« Reply #3 on: June 10, 2012, 07:21:25 AM »
Offline MikeKato
  • Milwaukee WI
« Reply #4 on: June 10, 2012, 08:36:59 AM »
Thanks Stev-o but Hondamans ad says it doesn't fit the locking gas cap which is what I have. (the recall replacement).
« Reply #5 on: June 10, 2012, 10:42:03 AM »
It will work, it does not fit the locking cap LATCH.  You need to attach the cap to the tank, right?
Offline MikeKato
  • Milwaukee WI
« Reply #6 on: June 10, 2012, 08:05:40 PM »
 I reattached the cap with a 3m x .5m x 25m allen head and a 3m nut. I still need to do something about the phillips screw that travels through the whole width of the recall latch. Like to find a 3m x 40m allen and cut it to length. Helpful hardware man gave me a couple places to call tomorrow.
