Author Topic: Replacing Broken Throttle Cable (1982 CB650SC)  (Read 2602 times)
Offline leekellerking
« on: February 17, 2009, 12:54:31 PM »
I was on the way to work this morning when my throttle cable broke, leaving me stranded.  It is the "puller" cable that opens the throttle, not the "pusher" cable.
Any hints or tips about replacing the cable?  I have a replacement at home that came with the bike (the previous owner replaced the right-side switch but didn't have time to replace the cables).
From looking at the bike reading the previous related topics, I think I need (1) the "new" cable, (2) needlenose pliers and (3) a Phillips head screwdriver.  I fantasy that I will need to loosen the "pusher" cable at the adjustment doohickey.  Do I need to completely pull the tank?
Anything else you guys can suggest?
Also, can I lube the cables with Dupont Teflon spray?
Thanks,
Lee
(Whose bike is sitting at the Chevron Food Mart, like usual when it breaks down)   :'(
My Nighthawk is put together with wire and zip ties, burns oil, and handles like a pig.  I love it!
Offline OldSchool_IsCool
  • Really feeling like an
Re: Replacing Broken Throttle Cable (1982 CB650SC)
« Reply #1 on: February 17, 2009, 03:37:04 PM »
I think you have the general idea.  Pull out the broken cable being sure to note how it is routed.  Adjustments on each end to snug it up.
If the new cable is truly NEW, then no need to lube it now.  You can lube it in a few years then lube all cables each fall.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #2 on: February 17, 2009, 03:51:57 PM »
Unfortunately, it is not really new, just "new to this bike."  At this point, if it will get me running until the weekend, I will be happy.
Assuming I don't drown in the rain trying to fix it in the parking lot of a convenience store.   :o
Or push it the three miles home.   :(
Lee
« Reply #3 on: February 17, 2009, 04:17:46 PM »
You could also switch your push cable to the pull side of the carb butterfly.  Your grip will work in reverse, but it could get you home with a minimum of exposure to the weather.
If the replacement cable operates smooth, then really no need to lube.  Its really your call.
Sure.
Is it hard?
Offline NPHLYT
« Reply #4 on: February 17, 2009, 04:53:37 PM »
If you wait two weeks.......
Man I really need to change my avatar! I think I will gather up my 1970 into a pile and snap a photo. Maybe I will just snap a picture of the engine on the furniture dolly, looming over the frame laying dismembered next to it, tossing it's carburetors back, howling laughter in triumph over the oppressive cage..... In black and white to make it more sexy and timeless.
NPHLYT
1970 CB750 Mutt
1962 Sears Allstate Puch
Offline tomkimberly
« Reply #5 on: February 17, 2009, 05:30:27 PM »
You will also need two 10mm wrenches, one 12mm, and one 13mm wrench.
Tom
« Reply #6 on: February 18, 2009, 06:49:58 AM »
Hmm.  What is the 13 mm wrench for?
I'm going to have to get Bikey home and work on him there.  I couldn't get it done last night and I'm going to have to pull the carbs to get access to the cable connector for the "pull" cable (which was broken at the twist grip cam).
Lee
Tom
« Reply #7 on: February 20, 2009, 09:14:50 PM »
Whew!  What a pain in the ass!  :o
I got both cables attached and didn't have to pull the carbs, which is good because I couldn't get them loose, anyway.
It took freaking hours and I still have to put the tank and seat back on, but I think I've got it right.
The joys of riding a vintage bike.   ::)
Offline tomkimberly
« Reply #8 on: February 20, 2009, 10:30:57 PM »
Lee
Tom
One never knows what brand of throttle cable a PO put on a bike. Stock at the grip is 12mm however I have seen some that required a 13mm. Better to have too many tools than not have the right one.
Tom
« Reply #9 on: February 21, 2009, 07:35:57 PM »
Oh, I see.  Good point.
I got my bike home Thursday with the help of Carl, a Two Wheeled Texan, and I got the cables changed out Friday night.
My cables use a 10 mm at the carb side.
I lubed them with spray teflon sprayed into the ends.  Should be better than nothing.
I may put new cables on the replacement list.  Now that I've changed them once, I think I could do it quicker next time.
Lee
Lee
Tom
Tom
