Author Topic: Starter problem 1976 CB750 K  (Read 3065 times)
GeorgeK
« on: October 10, 2005, 04:02:22 PM »
I am new to the group so please be kind if the answer to my question seems obvious.
     I have a completely stock 1976 CB750 K with a starter problems. When I press the starter button I  SOMETIMES get a clicking at the starter and the starter does not engage.  It does not happen all the time. Sometimes pushing the button engages  the starter and the engine starts right up. The battery in the bike is brand new and fully charged. I did trying cleaning the starter button with some contact cleaner but that has not solved my problem. Do I need to replace the starter? Any suggestions will be helpful.
George
Offline Kevin D
  • SE Michigan
Re: Starter problem 1976 CB750 K
« Reply #1 on: October 10, 2005, 07:42:29 PM »
 George, I think what you are saying is that you hear the click but neither the starter motor or the engine spin. If so, the 12v at the battery has to get through the starter solenoid to get to the starter motor. Once it gets to the starter motor it has to go through the carbon brushes to get to the armature inside the motor. The clicking you hear is probably the solenoid. It's near the battery on my bike, under the side cover, cylindrical, 2 big wires, 2 small wires. The starter motor is under the chrome cover below the carbs.
 If you or your buddy has a voltmeter or test light you may be able to bug this out pretty quickly. Look for 12v on the big lead that goes to the starter motor, when you press the button. If the 12v is there solenoid looks good, shut bike off and check for circuit continuity through starter motor with meter on ohms, should be about ten ohms or less(sorry I don't know exactly) and not an open circuit.
 If you have no meter or light, tapping lightly with a screwdriver handle on the defective part (motor or solenoid) while you are pressing the starter button might make an intermittent circuit work temporarily.
 All that being said, when mine started acting up it was the carbon brushes. I rebuilt the starter and have had no further problems.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
GeorgeK
« Reply #2 on: October 10, 2005, 09:15:28 PM »
Kevin,
 Thanks for the info.  I do have a spare solenoid. I think I will  put it in and see if the problem goes away.
George
Offline Kevin D
  • SE Michigan
« Reply #3 on: October 11, 2005, 04:48:58 AM »
George - check out the interactive wiring diagram at http://oldmanhonda.com/MC/wiring750K1.html for CB750K1.
Similar, but not identical to yours. I think you may have clutch lever and/or neutral switch circuits between the push button and the solenoid - but if your solenoid is clicking, that says its trying to work.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
