Author Topic: Gunked up  (Read 1290 times)
stingray
Gunked up
« on: October 10, 2005, 05:59:40 PM »
After removing the rack of carbs on my '76 550 I have found that everything inside the bowl is coated with gum/gunk crap.
The float pin will not budge and everything is stuck.  I want to take everything apart to thoroughly, but is there anything that will remove (dissolve) the topical gunk so that I can crack things open?
Offline KB02
Re: Gunked up
« Reply #1 on: October 11, 2005, 08:02:47 AM »
This question was asked a little while ago, wasn't it?
I thnk the general concensus was libbral amounts of carb cleaner and letting it soak in for a while.
If you check back a few pages on this board, you'll probably find the post.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Gunked up
« Reply #2 on: October 11, 2005, 09:30:51 AM »
If you use regular carb cleaner then you`ll need to replace you o-rings but if they`re that gunked up they`ll need to be dipped anyway.And make sure you get all of the passages and jets clean.
Yamaha Carb Cleaner doesn`t affect o-rings but it`s not available everywhere.
It`s some delicate work as the towers the pins are in aren`t too strong.You can tap them out using a small punch or nail then grab them with needlnose pliers.
I use regular carb dip on mine such as Gunk or Berryman`s.
The first pic is after the carbs had been soaking for a while, the pins were all stuck too.
« Last Edit: June 29, 2007, 04:46:33 AM by Glenn Stauffer »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
