Author Topic: Cleaning Keihin carbs as a bank  (Read 2325 times)
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« on: February 21, 2009, 12:15:24 AM »
Any of you '77-78 F owners, or any year/model for that matter, ever clean these as a bank and not completely apart?
Also, any suggestions from F owners (77-78?) for jetting for pods? I don't think when the pods were installed, by the PO, that it was jetted accordingly.
I know that this is something that's tackled on a bike-by-bike basis and that my '77 F could act diff. from the next, but a ballpark would be great.
Stock is 105. Go up to 110 in a jet and raise the needle clip up 1 notch maybe?
Year Model Casting # Type Float   Main   Slow JN Screw
77   CB750F PD41B       2    14.5    105    35    2     1
« Last Edit: February 21, 2009, 02:46:48 AM by cb750fbomb »
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
KingCustomCycles.com
Re: Cleaning Keihin carbs as a bank
« Reply #1 on: February 21, 2009, 04:05:37 AM »
I never unstack the rack unless I find a broken/nonrepairable body.  I have had to unstack maybe twice in 160+ carb cleanings.  Your jetting estimate seems reasonable.  Remember, jets control idle and full throttle.  The midrange and transitions are all on the needle.  When tuned correctly, those F models are a blast to ride.
Offline Spanner 1
« Reply #2 on: February 21, 2009, 04:40:57 AM »
Look at the big carb. brain on you, Bomb....jets,needles.. how much of this did you know  1 month ago ??
Ain't it great ?  Ya gotta love this forum !
Offline cb750fbomb
  • is by no means a
« Reply #3 on: February 21, 2009, 04:50:15 AM »
I didn't know a thing and I still don't!!  :) I'm mildly terrified of getting this back together and it being worse. It sounds like it should go something like this:
Remove carbs, adjust, install carbs, remove carbs, adjust, install carbs, test, remove carbs, adjust, install carbs, test, remove carbs, adjust, install carbs, test.............
'77 CB750F2
Offline cb750fbomb
  • is by no means a
« Reply #4 on: February 21, 2009, 05:23:51 AM »
Any other changes? Do I need to change the slow jet size or anything else when the main jet and the needle position is changed?
'77 CB750F2
Offline KB02
« Reply #5 on: February 21, 2009, 06:03:25 AM »
That sounds about right.  ;D ;D ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline TheHun
« Reply #6 on: February 21, 2009, 07:09:45 AM »
how do you raise the needle?
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
Offline cb750fbomb
  • is by no means a
« Reply #7 on: February 21, 2009, 07:28:18 AM »
Faintly circled in red, tried to do better with that part, are what look like venturis but only one has an air passage. The one on the left looks melted and the one on the right looks fine. How did this thing melt, what are these and how do I replace them?
« Last Edit: February 21, 2009, 07:49:28 AM by cb750fbomb »
'77 CB750F2
Offline cb750fbomb
  • is by no means a
« Reply #8 on: February 21, 2009, 07:45:32 AM »
BTW, the main jets are already 120's. Hopefully she'll be running well here soon with clean carbs, properly oiled pods, new plugs, oil change....... I also had to get new push and pull throttle cables. The old ones were stretched out about 5 inches a piece.
'77 CB750F2
Offline scondon
  • Mmmm......tasty bugs
« Reply #9 on: February 21, 2009, 09:27:41 AM »
The piece circled in red is a stand pipe for the accelerator pump. When the throttle is twisted, the accel pump squirts gas through these pipes. I have no idea what could cause one to end up in such a condition.
    I would imagine they are press-in, much like the pilot jets. I'm not sure how well they would stand up to a pair of pliers though. Maybe test to see if it is functioning first. Fill bowls with gas and operate the throttle, gas should squirt out of all four.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #10 on: February 21, 2009, 09:28:23 AM »
 Thats the accelerator pump nozzle. The one on the left looks broken. Thats where the fuel is squirted in to the carb bore.
  I ALWAYS dismantle the carb bank for cleaning. Especially accel pump models. They have very tiny holes in them and get clogged very easily. Dismantling them completely is the only way to "get it right" and to "get it right the first time".
   If crud is stuck in the fuel line connections (from the tank, accel pump lines,etc) and not removed with a thourough cleaning, it will end up in your tiny passages of the carbs and you will be removing them again for another "not to thourough" cleaning. Any crud that is stuck anywhere in the system will find its way to be an inconvienence.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: February 21, 2009, 09:50:51 AM »
With most others it's like pulling teeth trying to get them to accept the fact that they need to pull their carbs and work on them, but you catch on quick!! ;D
You'll be much better off for it in the future.
Offline Jim F
  • go baby go
« Reply #12 on: February 21, 2009, 12:47:10 PM »
When I installed pods and a header system using stock carbs.
I went 1 size larger on the pilot
raised the needle (lowered the clip) 1 place
and went 2 sizes up on the main and that seemed to be a good point to start checking
your plugs if you don't have access to a dyno and most people don't
good luck
Big-Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
