Author Topic: STALLED '76 CB750A  (Read 2264 times)
lcooley452
STALLED '76 CB750A
« on: February 21, 2009, 11:02:37 AM »
Took the fairing off my CB750A and it ran. Finished rewiring half the lights and it ran by kick-starting. Finished wiring the rest, including the headlamp, and now she won't start. I've tried all the service manual troubleshooting suggestions except for testing the spark plugs. Could it be a short in the wiring? - Lee in AZ
Offline WFO
  • Will work for powerbands
Re: STALLED '76 CB750A
« Reply #1 on: February 21, 2009, 11:22:35 AM »
retrace your rewiring steps until you find the problem.
82 cb650 sc nighthawk - 78 kz 650 b
KingCustomCycles.com
« Reply #2 on: February 21, 2009, 02:43:10 PM »
The black wire running to the coils is the power wire.  The blue and yellow are from the points.  Get a meter or test light and see where you are losing power to that black wire.  I believe the A model is wired like all the others in that the headlight switch is designed to cut power to the headlight when the starter is cranked.  If all else fails, find a switched positive wire and run it to the black wire at the coils.
