Author Topic: Question about caliper piston and brake lines  (Read 2526 times)
Offline BeSeeingYou
« on: February 21, 2009, 01:18:08 PM »
I am working on the front brakes on my 76F and of course the piston and pad are stuck.  I have read some earlier posts about using air pressure to force them out.  What is the best way to plumb the compressor to the caliper?  I have tried using my rubber tipped nozzle stuck in the inlet port but the nozzle seems to have some type of pressure release valve so it won't build up any great amount of pressure.  Or it is just a #$%*ty Chinese made nozzle.  My other thought was to use the MC to push it out.  So I thought I would clean out the brake lines first.  The metal lines no problem but I can't blow any air through the rubber lines.  I tried to run a small wire through to clear out any obstruction.  I can get it in about 1/2-3/4 inch in on either end and then I am stopped cold.  I can't imagine any obstruction would be that solid.  How are these built?  Is their some type of check valve built into the connectors.  The lines themselves are in excellent condition and the fluid I was able to get out of the steel lines was fine.  This is all new territory for me even though I have run my XS650 for 29 years my only experience with the brakes was to periodically open up the bleeder screw to change fluid.  I have never had them apart.
Offline Bill Vaughan
Re: Question about caliper piston and brake lines
« Reply #1 on: February 21, 2009, 01:38:17 PM »
Several ways to do it and I'm sure others will post with their preferred methods, but I like to use a grease gun.  I just unstuck a 550 caliper piston that sat unused for the past 20 years.  Air, up to 120 lbs. wouldn't do it.  The hand grease gun got it out in 30 seconds.
Just remove the bleed fitting, install the threaded hose connection from the gun and pump away.  It's important to note that the threads won't be the same, so be careful here.  Thread the hose in lightly until you feel resistance.  You just want to get it to stay in place.
It should go without saying, but be sure to clean the caliper afterword.  No grease can remain in there.
« Last Edit: February 21, 2009, 10:58:48 PM by Bill Vaughan »
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline Bodi
« Reply #2 on: February 21, 2009, 01:43:46 PM »
The lines don't have any obstruction built in. Sounds like they're plugged with something nasty.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: February 21, 2009, 02:25:53 PM »
A bit of Teflon plumber's tape helps seal without having it be too tight.
Offline moham
  • .fnord.
« Reply #4 on: February 21, 2009, 02:29:43 PM »
Nice tip.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline Bido
« Reply #5 on: February 21, 2009, 03:24:04 PM »
I second the grease gun.
Bido
1978 CB750 Supersport F3
1981 CB750 K
Offline fmctm1sw
« Reply #6 on: February 21, 2009, 06:01:14 PM »
I've had success just using a good master cylinder and forcing the pistons out.  I salvaged a line once by running an old clutch (or was it a throttle) cable with the end snipped off through it...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fishman_Phil
« Reply #7 on: February 21, 2009, 09:13:51 PM »
Watch that compressor method. The piston can come out with a bang and fly across the garage and in the worse case do some damage to something else. Grease gun is the best method I have used and even if you do not have a good fitting nipple, it only needs to be bare started to enable this method to work.
1972 Honda CB350F (2); 1975 CB400F; 1983 CBX400F (1); 1962 Suzuki MA50 (1); Suzuki M15 (3); Suzuki M15Mk2 (2); Suzuki M31 (2); 1936 James H12 (2); 1948 Triumph Speed Twin 500; 1989 Suzuki GSXR250F; Yamaha Chappy (2); alot of work yet to be done.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #8 on: February 22, 2009, 07:14:34 AM »
Got to agree. Just done 2 calipers that have been in a scrapyard for 20 years, using the grease gun method.
As usual, it took longer to bleed the grease gun than removing the pistons
mutt
« Reply #9 on: February 22, 2009, 08:15:06 AM »
i put a piece of wood where the pads would go,then jam the rubber tip of the compressors blower attachement in the brake line hole. The woods eases the impact on the rapidly expelled puck, no grease to clean up. .....
Offline ajinreno
« Reply #10 on: February 22, 2009, 07:54:13 PM »
I'm kind of in the same boat. I've never done more than bleed and change pads. Just bought a 78 750F this weekend and took rear and front calipers off because they were sticking. I should be able to just pull the caliper pistons about by hand correct? They don't seem to be budging so I'm guessing I need to use a grease gun. I'm a bit of dolt so if someone wouldn't mind verifying if this is correct I'd greatly appreciate it.
Offline ajinreno
« Reply #11 on: February 23, 2009, 06:55:09 PM »
So I was assuming the MC works because the back wheel was free when I loaded it in my truck and then when I took it out and applied the rear brake is when it stuck. That's when I took it off and realized the piston seemed to be frozen. I hooked it up again, as recommended, to get the piston out. But it still didn't move. So I thought maybe I need to bleed the brakes first. I started bleeding and the air bubbles never stopped. I probably did it about 20-25 times and their was continously air bubbles. Does this mean something wrong with either the MC or the lines?
« Reply #12 on: February 23, 2009, 07:19:02 PM »
Grease gun has been the easiest and safest for me. IF an air compressor will work then it will create a high speed large projectile that WILL damage whatever it hits. You, your car's window, your dog, your kid, etc. A grease gun will ease it off. Rather than remove the bleeder valve why not just slightly open it and attach the grease gun nozzle to the bleed valve nipple! Put one of your other bolts into the other hole just don't screw it in so far as to damage the pieces inside. Worked for me plus no cross threading. If you don't have a grease gun, you need one for the swing arm anyway.
Offline papp101
« Reply #13 on: February 23, 2009, 07:49:38 PM »
I wanted to thank you Srust for posting this, as I have some crazy similarities to your post:
1. My birthday is Feb 9th, the day you bought your CB750.
2. I live in Minneapolis.
3. I spent 2 hours today using various methods of abuse on a caliper that has not been used since 1975.
4. I tried plumbing my compressor to it.
5. I used my Harbor Freight (Cheap Chinese) rubber tip to press up against the steel tube, all to no avail.
6. I told myself to go search about it before breaking the thing into pieces.
Hopefully I can grab a grease gun to use on my caliper so it will release this week.
My master cylinder was missing all sorts of parts from the previous owner, so a replacement of sorts there will definitely be in order.
Thanks for posting it man! Maybe someday I can pimp you for ideas for my 1979 xs850 Triple I've got to fix and sell!
Offline motorhead55
« Reply #14 on: February 23, 2009, 10:34:04 PM »
REPLACE the rubber hose! It has deteriorated inside. Rebuild the caliper and master cyl, replace the brake hose, clean out the steel line and THEN use SILICONE brake fluid. I have had that in my 550 for 15 years and in the Porsche drum brake system that I have on my '55 Vw for 18 years. I haven't had any leaks, stuck pistons, ect.
1976 Honda 550F bought new in 1978
2006 Yamaha TW200 TrailWay
1967 Triumph 200cc Tiger Cub
2007 Dodge 5.9 Cummins Diesel, 6spd. Stick, 4X4
1955 European Spec VW Bug, 1700cc engine, Porsche 356 "A" brakes
1939 Willys Pickup
2003 Kubota B7400
« Reply #15 on: February 24, 2009, 08:45:22 PM »
The front brake hoses are still available from Honda. I just got 1 in and the other is on the way from another supplier. Braided stainless is nice too. However, the rear is not available.
Motorhead is going to get some stink raised about SILICONE fluid as usually happens BUT I'm with him on that. I put silicone in the front after my rebuild and powder coating of the caliper, rotor, and front fork legs and it works just fine PLUS it won't eat the paint when the seal leaks again. FWIW I still have DOT4 in the rear and it works fine too but I will change that when I do the restore.
