Author Topic: Rickman or other half (frame mounted) fairing bracket photo & measurements  (Read 25587 times)
Offline UnCrash
  • Pass
    • My Blog
Ok, I wasn't sure where to put this post but having seen a few requests for this kind of information over the years I thought I would document the fairing bracket that came with my Rickman.
There are lots of pictures with a measuring tape so it shouldn't be too hard to re-create this kind of bracket by one with knowledge and skill in the metal working arts  ;)
The fairing is held in place by 3 stays.  One connects the back wings of the fairing to the frame, the other two connect the main bracket to the gas tank posts.
The main bracket holds a standard headlight bucket at the bottom set of holes.
Here's the rear stay:
In this picture below you can see that there is an additional piece of metal needed which will go on top of the frame rail and bolt into this bottom one.
Next is the main bracket:
Notice the two little tangs at the bottom of this part.  They sit on either side of the steering lock on the neck of the bike providing lateral stability to the fairing.  Pretty clever.
Here's the main bracket stay:
And the main bracket stay attached to the frame and main bracket:
With the fairing on:
Now time for paint!
Re: Rickman or other half (frame mounted) fairing bracket photo & measurements
« Reply #1 on: February 22, 2009, 12:50:27 PM »
i love the deceptive shots of you holding it with the tape measure in the background ....  i was lost in the optical illution for a second  ;D ;D
« Reply #2 on: February 22, 2009, 02:16:36 PM »
Excellent photos Ben and this makes it much clearer how the brackets and fairing go together - thanks very much for enlightening me!
cheers
Andy
masonryman
« Reply #3 on: February 22, 2009, 03:49:26 PM »
Thanks for that, I just ordered a small fairing. If I don't like what comes with it, that will give me a starting point.
Mark
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: February 23, 2009, 03:12:58 AM »
Those little "tangs" also reduce the steering lock so that you don't trap your fingers against the fairing when turning the bars. Low speed manouvreability sucks though!
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #5 on: February 23, 2009, 06:21:52 AM »
Steve not sure if the PO had the correct bars (Clubman's ????)on but my fingers did jam when turning the bars,it was on a 74 550.
Ben the fairing looks a little different than when I last saw it....thumbs up
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
    • TVAM
« Reply #6 on: February 23, 2009, 06:25:03 AM »
That's an MOT (Inspection) failure over here, which is why Rickman designed them that way.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline UnCrash
  • Pass
    • My Blog
« Reply #7 on: February 23, 2009, 08:07:48 AM »
Thanks tjjkc.  No bondo, but I laid fiberglass over a couple of the impact areas inside.  Sandable primer covered up the tiny spider cracks on the outside very well.
The fairing feels like it stiks way out front... I need to mock it up with my triple tree and clubmans and make sure everything fits ok.  Were there clubmans on the 550 that this came off or were they clip on?
    • TVAM
« Reply #8 on: February 23, 2009, 08:21:13 AM »
On the bike in my avatar, one of my passengers famously stated (after a run to Brands for the Easter Transatlantic Trophy races) "It's like the Starship Enterprise from back here!"
My bars were "Ace" bars (Clubmans)
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline UnCrash
  • Pass
    • My Blog
« Reply #9 on: February 23, 2009, 08:34:09 AM »
Thanks for that Steve.  Looking at your avatar pic mine looks about right.  Would you happen to have a larger version of the image which you could post?
Cheers~
    • TVAM
« Reply #10 on: February 23, 2009, 08:45:30 AM »
These were taken on the bike's 50,000th mile "birthday" in Feb '80
It had a 550K3 seat and tank.
A Rickman Type 2 fairing.
Piper 4-1
Fiamm air horns
Drilled disk
Cibie headlamp
Bar-end mirror
SOHC4 Member #2393
2015 Tiger 800 XRT
  • Newcastle Ontario
« Reply #11 on: February 23, 2009, 09:18:21 AM »
Ben.......the bars that were on were Clubman's .no idea of the brand,I will see if I can find a pic of it.......
Communicate
Offline UnCrash
  • Pass
    • My Blog
« Reply #12 on: February 23, 2009, 09:24:41 AM »
Thanks for the pics Steve!  Really helpful.  I was also wondering as to the nose angle of the fairing as my bracket holds the nose higher than I would expect, but it looks like it will be the same  as yours.
& tjjkc, no worries I have a set of vintage clubmans to go on the bike.
  • Newcastle Ontario
« Reply #13 on: February 23, 2009, 09:28:08 AM »
Not the best pic the only one I could find.
Tom
Communicate
    • TVAM
« Reply #14 on: February 23, 2009, 10:50:26 AM »
I don't remember the height as being adjustable as it is dictated by the front mounting bracket (which is why the 400/500/750 brackets were slightly different).
At the end of the day, your hands shouldn't hit the tank on full lock or get trapped underneath the fairing on the opposite lock.
My Rickman 750 traps your hands badly...   8)
« Last Edit: February 23, 2009, 10:52:59 AM by SteveD CB500F »
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline UnCrash
  • Pass
    • My Blog
« Reply #15 on: February 23, 2009, 12:18:12 PM »
My Rickman 750 traps your hands badly...   Cool
Steve,   yours does sit a bit lower and closer.  Looks good  :D
Thanks tom that picture confirms my opinion.....
Now I'm going to mock up the front end and see what I can do about the height without getting my hands trapped.
Offline Ricky_Racer
« Reply #16 on: February 23, 2009, 03:12:36 PM »
Just FYI, Steve... I have the same clearance problem on my Rickman CR with Rickman clipons. I think I'm going to go with adjustable 41mm Tommasellis on the next one to see if I can fine tune the riding position just a little.  RR
Offline UnCrash
  • Pass
    • My Blog
« Reply #17 on: February 23, 2009, 05:33:46 PM »
WOW RR, your bike is beautiful!
Any side shots of it?
Your fairing looks lower, did you modify the stock bracket to have it sit lower?
Offline Ricky_Racer
« Reply #18 on: February 23, 2009, 06:38:45 PM »
Thanks, Uncrash. Stock Rickman brackets.
Not many pics right now, and currently she's partially disassembled so I can polish the frame nickle-plating.  I've had her many years but I'll be making her available soon so I can complete other projects.
I've attached a couple shots that may better show you the position of the clipons. Just note that the full fairing for the Rickman CR is slightly different from the Rickman fairing for the CB750 and may not sit in exactly the same position. RR
    • TVAM
« Reply #19 on: February 23, 2009, 11:03:13 PM »
Purely as a point of interest (of course!), there's one on eBay.co.uk at the moment with a fairing that has been cut and molded to the engine/frame. I've not seen anything quite like it - but it looks good.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline UnCrash
  • Pass
    • My Blog
« Reply #20 on: February 24, 2009, 04:50:22 AM »
Beautiful bikes RR & Steve.  Thanks for posting.
All are inspiration to complete mine.
RR your pictures are helpful and it does seem very similar to how my bracket will hold the fairing.
I'm going for the black look.  The fairing is on an F3 after all...   ;D
Offline hagar24
I know this is a old topic but can anyone here tell me where I can get a Rickman tank and what newer bike rear sets would fit on it??
I have a CR 750 I need to restore in Jamaica.
Thanks
Offline Ricky_Racer
Hagar, the only one I know of who's making Rickman tanks is Air-Tech. They got ahold of a Rickman-Kawasaki and pulled a mold from the standard Rickman tank. That pattern was made for the Rickman chassis so if you're doing an actual Rickman, it should fit well. The Honda-Rickman CR750 tank had two cutaways in the bottom to clear the carb adjusters, so you might need to ask Air-Tech if their tank does as well.
You'd probably be best served using Tarozzi rearsets on a Rickman chassis. My previous Rickman CR used Laverda Jota rearsets and they were similar to the current Tarozzis. RR
Offline hagar24
Ok, so I have not been on here for a while, I just wanted to say thanks to Rickey Racer for the response to my question.
Offline Rickman88
Hello,
Is this the fairing bracket?
I would like to mount the Airtec fairing:
So, I need other tools to fit it?
Regards
Enviado desde mi iPhone utilizando Tapatalk
Rickman Honda from Barcelona, Spain :)
