Author Topic: Lights kill engine  (Read 1388 times)
DaveNTexas
Lights kill engine
« on: February 22, 2009, 07:08:31 PM »
Battery is low after the winter; jumped bike to start, and took off.
As soon as I flipped on headlamp, engine died like it was shot.
Repeated event after restart.
Have removed battery.  1yr old.  2 months since ran last.  Fluid fine.  Will attempt to charge then try new battery if no joy.
Offline 750goes
  • it will live
Re: Lights kill engine
« Reply #1 on: February 22, 2009, 07:12:37 PM »
may not be battery - but a short in the headlight switch itself....
« Reply #2 on: February 22, 2009, 09:52:06 PM »
You are on the right track.  Low voltage kills the spark.  Headlights lower the voltage on a weak battery.  The alternator doesn't take over running the bile electrics from the battery until about 2500 RPM.
DaveNTexas
« Reply #3 on: March 17, 2009, 08:25:57 PM »
New battery fixed problem!
Waiting to see if charging circuit will keep battery up.
Also, see this post for new problem!
http://forums.sohc4.net/index.php?topic=48279.0
