Author Topic: CB350 Exhaust on CL350 Bike?  (Read 1841 times)
Offline OakBehringer
« on: February 26, 2009, 11:58:24 AM »
Quick question - Everything I read leads me to believe that any CB350 exhaust - oem and aftermarket - should be a direct bolt-on for an CL350. Am I correct to assume this?
Thanks,
Adam
p.s. already posted this on the hondatwins forum, but didn't get a response. I apologize to anyone who may read this twice.
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline tbpmusic
Re: CB350 Exhaust on CL350 Bike?
« Reply #1 on: February 26, 2009, 12:14:19 PM »
Sorry - I didn't see your question over there.
You should be able to do that with no real problem...
Bill Lane
« Reply #2 on: February 26, 2009, 12:16:44 PM »
Yea, should bolt onto the motor with no problem. I'm not sure how the cb exhaust mounts to the frame... unsure if the CL frame would have the same stuff.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #3 on: February 26, 2009, 02:35:30 PM »
You may have some interference with the footpegs, other than that, I think it's a straight bolt on....
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
« Reply #4 on: February 26, 2009, 02:36:30 PM »
CB and CL footpeg mounts are different. CB has room for a pipe between the frame and peg. A CL does not.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
