Author Topic: torque question  (Read 1706 times)
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
torque question
« on: October 12, 2005, 06:10:30 AM »
OK.  I've got my carbs back on and she fired up on the first try, but once heated up she backfiring like mad.  I know she probably a little lean as the air filter is totally clogged (a new one is on order) so it's sitting on a shelf right now.  I tried to snug down the headers and had to replace 2 studs at less than 18 ft/lbs.  I need to make sure the headers are tight (sounds like there's a slight leak) but don't want to keep replacing studs unless they're actually bad but I can't find the torque specs in the manual or here online.  Anyone know how tight I should get em?
Thanks
James
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline mick750F
Re: torque question
« Reply #1 on: October 12, 2005, 06:23:14 AM »
   Don't now what the torque spec is, can't find one in the manuals. I've always gone with whatfeels right. Have you replaced the exhaust gaskets? If not, that could be causing your leak problem.
Mike
Glosta, MA
eldar
Re: torque question
« Reply #2 on: October 12, 2005, 07:23:14 AM »
The headers can take a fair amount of torque. That is not to mean that you take an air hammer after it but 30 pounds or so should not be a problem. You should replace your gaskets though anytime you remove the headers though as they crush down to form a seal.
Offline dusterdude
Re: torque question
« Reply #3 on: October 12, 2005, 07:35:39 AM »
james,eldar should know,he`s the k8 god
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: torque question
« Reply #4 on: October 12, 2005, 07:50:18 AM »
Awesome.  I've got gaskets on order and a couple spare heads to get studs from if I break any more.  I thought I should be able to put a little more behind them.  I'll snug them down for now till the gaskets get here.
I brought the girl into work this morning, backfiring and all, and love the feel.  After the chopper it's like riding a really fast bicycle.  She actually handles and I can sling her around like she's 50lbs.  Great feel!
eldar
Re: torque question
« Reply #5 on: October 12, 2005, 07:52:03 AM »
Now duster, green is not your color! Maybe a light shade of pink??? ;D
Re: torque question
« Reply #6 on: October 12, 2005, 08:06:02 AM »
Standard Bolts 6mm thread 5.7-8.6 Ft Lbs; 8mm thread 14.5-17.3 Ft Lbs
Offline dusterdude
Re: torque question
« Reply #7 on: October 12, 2005, 08:53:48 AM »
ill withhold comment until i get done laffin.you`re killin me eldar
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
eldar
Re: torque question
« Reply #8 on: October 12, 2005, 09:32:57 AM »
A good laugh once in a while is good for you!  At least I stopped to wait for you ;D
Offline dusterdude
Re: torque question
« Reply #9 on: October 12, 2005, 10:18:37 AM »
thank you,thank you,thank you.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
