Author Topic: Primary shaft removal?  (Read 831 times)
aesache
« on: February 27, 2009, 06:41:53 AM »
hi all i am trying to remove the primary shaft from the cases on my 350f. the manual says there is a special tool to do this or that a suitable bolt can be used. has anyone done this? what size bolt does it take and is there anything i should know before attempting it
also the only reason i am removing the primary shaft is because i need to split my cases i am right in thinking that it has to be remomved before the will come apart right?
aesache
Re: Primary shaft removal?
« Reply #1 on: February 27, 2009, 08:00:41 PM »
i figured it out typical newbie mistake i tryed to pull it out from the wrong side....
