Author Topic: budget billet pegs , cheapy headlight mount.  (Read 6008 times)
Offline jeepurz
« on: March 03, 2009, 04:13:54 PM »
two led flashlights from autozone, 10 bucks.
old 550 pegs removed rubber.
snadblasted pegs matched the two mount hole  gutted flashlight and drilled two holes in tube
repaint mount screw em on.
they still fold and you get 6 freebie aaa batteries
cut up old fork lower the size of the distance between trees.
I drilled these for effect
then painted em  and put em on.
when im done with the 550 ill get the finished pic.
heres the same setup on my yamabob
Offline mystic_1
  • 1970 CB750K
Re: budget billet pegs , cheapy headlight mount.
« Reply #1 on: March 03, 2009, 07:38:19 PM »
Zounds!  Great work on the fork-lowers-turned-fork-covers.  Ingenious!
mystic_1
- John Augustus Shedd
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #2 on: March 04, 2009, 06:53:22 AM »
way cool  :)
I may have to try the flashlight pegs trick
Offline 78CB750CAFE
  • I'm not really an
Offline 78CB750CAFE
  • I'm not really an
« Reply #4 on: March 04, 2009, 11:14:47 AM »
2 for $5 @ Advanced Auto Parts (black only, plenty more if anyone wants some)
15 minutes
THANKS!
Offline jeepurz
« Reply #5 on: March 05, 2009, 04:46:10 PM »
http://cgi.ebay.com/NEW-MINI-3-AAA-9-LED-FLASHLIGHT-TORCH-SET-BRIGHT-LAMP_W0QQitemZ380106699927QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item380106699927&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A15|39%3A1|240%3A1318
does this look like the flashlight you used?
yup, I figured Id have to rig spacers, or silicon after mounting but they actually slid on no grinding shimming or filler.
I originally got the idea on my tracker using gocart billet peg covers, they worked good but required welding shafts and cost a whopping 12bucks, & I didnt get free battery's.
« Reply #6 on: March 06, 2009, 07:59:49 AM »
I could probably whip up some billet, knurled right across slipon jobs..
but probably be beteween 35 -40 bux a set.. if anyone wants them..
Offline 78CB750CAFE
  • I'm not really an
« Reply #7 on: March 06, 2009, 09:11:41 AM »
something a little thicker walled then these flashlight bodies would be cool, these work well so far, but it is prob just a matter of time before they deform and/or the bolt holes spread too much making them rattly and anoying. They look cool and feel good under my boots, I had been running just the inner peg w/ bolts for traction and these are definitely an improvement.
LMK if your into making some, I might hold off anodizing my brake anchor arm and do a batch w/ the pegs.
« Reply #8 on: March 08, 2009, 09:36:51 PM »
Sorry for late reply.
 I assume you want closed end?
 How about a 1/2 round lip on outer edge?
 Maybe a bit of a bump or slight raised portion in middle of the end? Dress it up a bit.
 How about a relatively close fit, then you can urethane glue them on? or if a screw, a single countersunk, near the pivot should work.. (so you dont see it in use)
 754
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
« Reply #9 on: June 15, 2009, 05:05:34 PM »
I like the idea also but wonder how they will hold up. Those flashlights do seem to be pretty thin.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: June 15, 2009, 07:06:08 PM »
For the cost, you could almost replace them every year.
mystic_1
Offline 78CB750CAFE
  • I'm not really an
« Reply #11 on: June 16, 2009, 07:59:29 PM »
I have had mine a few months and a few thousand miles...
I lost one end cap during Rolling Thunder, but have a few replacements so no sweat.
Cheap cool fix
