Author Topic: Today's ' Daily Doofus ' !!  (Read 1402 times)
Offline Spanner 1
« on: March 10, 2009, 03:15:47 PM »
Watch-out for this one, lads !
I decided that I didn't like my 102 mains as supplied with the Keyster re-build kit (PD 44B carbs) and today decided to go back to the 108's that were in the bike when I got it. The 102's being, i.m.o. just too lean, producing a light gray plug, and a possible over heat now that were facing another Summer etc., blah, blah.
I put back the 108's and the old needles, fired-up and #4 smoked like mad and eventually fouled the plug..luckily #4 float bowl is accessible...everything was perfect in the bowl.
Turned-out that in taking-out the carb. slide I had rotated the carb. bank for some reason and when I dropped the slide back in it was facing the WRONG way with the cut-out section facing into the carb.!!!   There  is no 'keyway' and slider will go in either way quite happily...slide reversed= very rich cylinder !!!
Re: Today's ' Daily Doofus ' !!
« Reply #1 on: March 10, 2009, 03:26:52 PM »
I'll have to remember that one as I've just bought on.
What size are the carbs on the auto?
Sam. ;)
« Reply #2 on: March 10, 2009, 03:33:02 PM »
You sure it wasn't your ignition?
Oh wait, you said #4, not #3.
Nevermind...
Just thought I'd "slide" that one in there.   ;D
Cheers,  ;D ;D ;D ;D
Offline Spanner 1
« Reply #3 on: March 10, 2009, 03:37:06 PM »
L.O.L., T.T. !!! ( O.M.G. he does have a sense of humor !!! ).
Offline Spanner 1
« Reply #4 on: March 10, 2009, 03:41:16 PM »
 The 750 'Matics sport a massive 24 milly meter carb., verses y'all 'gearbox' guys at 28mm, yes ?
Offline Hush
« Reply #5 on: March 10, 2009, 04:24:19 PM »
Damn too quick TT I wanted to ask about #3! ;D
That is unusual eh Spanner, all the bikes I've had in the past had a small keyway taht kept the slide in the forward direction.....I guess Honda knew that only discerning owners would buy Hondas' and therefore would be clever enough to figure this out. :D
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #6 on: March 10, 2009, 05:11:54 PM »
OH SNAP!!!!
333:  Think "Shakeweight".
Offline Bodi
« Reply #7 on: March 10, 2009, 07:00:20 PM »
Yeah, all the Honda 4 Keihin carbsets I've seen have the keys. But they were devious... two carbs key on the left and two on the right... so you can manage to reverse two or all four.
Offline Deltarider
« Reply #8 on: March 11, 2009, 01:10:42 AM »
I can see why you've chosen the 'auto'. ;D Now just concentrate on choosing the right riding position. There are two possibilities. Tip: 1. your nose - it's that 'keyway' thing between your eyes - should point in the same direction as the headlight. 2. Now your hands can grab the shiny bar in front of you. The one at the other end, above the red taillight, is the luggagerack. Riding in that position is not as exciting. Good luck and do send us pics! ;D
« Last Edit: March 11, 2009, 01:13:05 AM by Deltarider »
CB500K2-ED Excel black
Offline mrbreeze
  • Not your average
« Reply #9 on: March 11, 2009, 01:35:32 AM »
Its been awhile since I did my carbs but I do recall the book and people here saying that you can accidently put the slides in backwards. Wouldn't you catch this when the bank is all assembled and you are looking through the venturis operating the throttle??? If not then....when you are bench synching?????
MEMBER # 257
Offline Spanner 1
« Reply #10 on: March 11, 2009, 02:44:37 PM »
Hey, Delta, while your riding position is supposed to be funny !!, actually you COULD ride an Automatic with one hand on the handlebars and one hand on the luggage-rack behind...HA HA !!    Y'all are just jealous  'cos you can't take-off from a traffic light ONE-HANDED, to the amazement of other bikers and road users !!
Hey, mr.Breeze, I didn't separate the carbs. and had vac. synced them about a month ago, so sync. was not disturbed by taking them off the bike !
