Author Topic: Unknown part  (Read 1078 times)
Offline 77honda
Unknown part
« on: March 12, 2009, 02:01:06 AM »
I am rebuilding my engine and am about to install the top case and then I found a small dowel/bush it is 15mm od x 13mm id x 10mm long
I have looked all through the fich but can't seem to find where it belongs. When I dismantled the engine everything went into plastci containers and then I labeled them, this was in the case bolts box.
Can anyone help identify this and where it goes.
Thanks Mike
CB750 K7
Offline GammaFlat
Re: Unknown part
« Reply #1 on: March 12, 2009, 02:10:49 AM »
Did you disassemble your airbox?  I've seen parts that look just like that.  They're used to align the bolt and gasket between the upper airbox shell and it's bracket.  See the pic below (#9).
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline GK
  • Cafe novice
  • novice cafe builder
Re: Unknown part
« Reply #2 on: March 12, 2009, 02:15:44 AM »
you sure it's not a dowell for helping align covers to cases?
hold it flat!
CB 400F cafe build/ http://forums.sohc4.net/index.php?topic=48734.0
Offline 77honda
Re: Unknown part
« Reply #3 on: March 12, 2009, 02:19:56 AM »
I will check tomorrow, I think it might be from the oil pump, as you said GK it may be one of the alignment dowels were the pump bolts to the case.
Thanks, for you help guys.
Mike
CB750 K7
Offline GammaFlat
Re: Unknown part
« Reply #4 on: March 12, 2009, 02:22:10 AM »
I think GK's got it.  My valve cover had those hollow "alignment dolls".
K6
K7
Offline greenjeans
  • 1972 CB750K2
Re: Unknown part
« Reply #5 on: March 12, 2009, 04:19:40 AM »
What's it made of ?  Steel or aluminum ?
Re: Unknown part
« Reply #6 on: March 12, 2009, 07:18:35 AM »
It sorts looks like cad plated steel, which makes me think external spacer..
 all the ones inside the motor were not plated
Offline 77honda
Re: Unknown part
« Reply #7 on: March 12, 2009, 01:43:35 PM »
It's made of steel and the od has been ground or sanded smooth. there is a seem in it so it has been rooled into shape not machined.
Mike
CB750 K7
Offline many408
Re: Unknown part
« Reply #8 on: March 13, 2009, 07:18:14 AM »
Mike
That's a bolt-spacer then.  Locating dowels are ground steel tubing or rod, with beveled ends.  Don't worry, it wasn't supposed to be in your engine - somewhere else, hopefully easier to get to.
Re: Unknown part
« Reply #9 on: March 13, 2009, 11:01:53 PM »
I think I got it..
 Headlight shell bushing, where the mount bolt passes thru... ;D
Offline 77honda
Re: Unknown part
« Reply #10 on: March 14, 2009, 01:48:58 AM »
Thanks for the help, I have found what it is. It one of three alignment dowels for the oil pump
Item 9
Thanks for the help, worried I forgot something
Mike
CB750 K7
Offline GK
  • Cafe novice
Re: Unknown part
« Reply #11 on: March 14, 2009, 02:51:59 AM »
cheers,GK.
hold it flat!
