Thanks Gordon.
I checked spark and it was good. I checked the carbs for gas and #3 was empty. I was able to remove the bowl and removed the float and bent the tab a bit, and then checked for operation.
It ran. Not perfect, but of course the rings aren't seated yet and the carbs are misadjusted. Pretty proud of myself actually.
Interesting, this was the only carb that I measured and bent the tab when I rebuilt them. The picture in the manual isn't clear and I figured that if it ran perfectly before I had to rebuild it then I shouldn't monkey with them. I'll sort this out soon as I will need to remove the carbs again when I get a replacement arm for the choke next week.
OK, it was smoking a bit -- prolly normal in the first 5 mins but a bit more from #1 which has me a bit worried since that's were my rebuild started in november with the #1 exhaust valve guide. There was a ton of oil in that pipe from the failure so maybe it's still smoking from that?
I'm hoping to warm it up, get it a bit synchronized and take a spin tomorrow morning. A little bit closer every day!
Zeke
