Author Topic: 76 CB750 non runner for 10 yrs What should i do to get running other than obv  (Read 1687 times)
Aerobhoy
 Need Help!!  I've just bought a 76 CB750, That was Garaged and not run for at least 10yrs.
It Has no brakes,  Clutch cable siezed,mabey more?
Other than stripping carbs, installing battery,new oils, rebuild brake master and caliper, checking wiring.
what would you recommend before trying to turn over, is there anything i should do to the engine like check valve adjustment's  :) Engine does turn with kickstart,
http://i183.photobucket.com/albums/x161/cobrabhoy/HondaCB750four398.jpg?t=1237002968
http://i183.photobucket.com/albums/x161/cobrabhoy/CopyofHondaCB750four409.jpg?t=1237003072
thanx in advance
Jimmy O
Offline 750goes
  • it will live
do a complete tune up
put a few drops of oil down the cylinders before you try to start it (first job to do before the tune up starts))
after the tune up of course with everything checked if everything is good then it should start....good luck
check list should be on here somewhere - search for one
Offline BeSeeingYou
Check the gas tank.  It may need a good cleaning
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
First thing I always do is pull the plugs and valve caps and give every hole a good dash of oil
before I turn it over,manually.   Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Offline ajfriz
A very common problem is electrolysis occurs on the points after sitting for a few years.  The bike will run, but not very well if you don't change them. Filing them doesn't work either because the electrolysis gets so bad from sitting for so long.  Save yourself the headache and replace them. I wish I had instead of wasting so much time trying to figure out why my bike wouldn't run well after going through everything. When I did replace them I was kicking my own a$$ for not replacing them sooner.
1970 CB750 (Under restoration) 1975 CB750
Offline GammaFlat
I've had a good look at your bike and I've come to the conclusion that you should sell it (to me).
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
