Author Topic: 73 750 oil lines?  (Read 1027 times)
Offline Speed King
73 750 oil lines?
« on: March 17, 2009, 09:05:29 AM »
I have a 73 750. One of the oil lines is leaking that come out of the bottom of the oil tank. Calling around & I can't find any. Anyone know where I could buy them?
Offline Old Scrambler
Re: 73 750 oil lines?
« Reply #1 on: March 17, 2009, 06:31:51 PM »
Is it the line or is the nut loose? Or maybe the tube from the tank is cracked. I have spares...........Let me know which one - sending or return - Use my email for a price quote with shipping.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
WHALEMAN
« Reply #2 on: March 17, 2009, 07:03:44 PM »
There is a crush washer in there. I would pull the fitting off the tank and check or replace the seal before I concluded that the line itself is leaking. Dan
Offline Speed King
« Reply #3 on: March 17, 2009, 08:03:50 PM »
Thanks guys- I'll get it apart & check it out.
Offline Alan F.
« Reply #4 on: March 18, 2009, 07:38:04 AM »
Part numbers....  the 14mm sealing washer for the oil lines to the tank is 94109-14000  The sealing washer for the drain plug on the oil tank and on the pan is 12mm part number 94109-12000  maybe a PO put the wrong one in?  The O-rings for the engine end of the lines is 15 x 2.5mm and is part number 93102-377-000
The lines are discontinued says servicehonda, best of luck finding the simplest cause for your leakage.
A quick check of Davidsilver, Cmsnl and Yamiya confirm Zero availability on non NOS, OEM style oil lines.
« Reply #5 on: March 18, 2009, 07:51:00 AM »
CycleX.com has something for lines, a kit to make your own or something like that. Carpy had stainless steel lines on his site but pricey IIRC.
here's CycleX, way down at the bottom... http://www.cyclexchange.net/Oil%20System%20Comp%20Page.htm
« Last Edit: March 18, 2009, 07:56:06 AM by MCRider »
