Author Topic: wiring question  (Read 936 times)
Offline Heirborn
wiring question
« on: March 21, 2009, 03:42:09 PM »
I have a '70 k0, cb750. When I tore the bike down the plug coming from stator to the harness was "fused" together and so I cut it loose without labeling the wire, I know, not a bright move. So now it is time to reattach the freed plug (I left leads to solder) to the wires coming from the stator. Problem is the 3 yellow wires that ultimatly end up at the recitifier. Since they are all the same color I can't differentiate.... my hope is that it does not matter how they go back on but have to believe that it does.
'70 CB750-Open Pipes and Pod Filters
'72 CL70
'07 Bonneville
Re: wiring question
« Reply #1 on: March 21, 2009, 05:37:29 PM »
I think I saw a wiring diagram here somewhere but I can't remember where.
Offline Spanner 1
Re: wiring question
« Reply #2 on: March 21, 2009, 05:41:47 PM »
Your right..makes no difference...just like a pie sliced in three each piece is the same...generally speaking, with electrical stuff if wires from a component are the same color then they hold the same ' value ' so all are alike !
