Author Topic: 1978 CB750K choke shaft assembly between two middle carbs  (Read 1542 times)
Offline flyingredhorse
  • 1981 CB900 Custom
    • Free Wild
« on: March 21, 2009, 09:47:39 PM »
I am having trouble placing the forked end of the choke shaft. The shop manual is vague and I somehow got digital pics of the disassembly from every angle but the one I need. and
I'd like a little of both.
Offline GammaFlat
Re: 1978 CB750K choke shaft assembly between two middle carbs
« Reply #1 on: March 21, 2009, 09:59:44 PM »
I have a set of 77/78 carbs off a bike - let me know what pic you need.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
  • 1981 CB900 Custom
    • Free Wild
« Reply #2 on: March 21, 2009, 10:18:03 PM »
GammaFlat - here is the drawing and a pic at the angle I need to see. . . thanks man. Its the view between the two carbs of the forked end of the choke shaft . . .
  • 1981 CB900 Custom
    • Free Wild
« Reply #3 on: March 21, 2009, 10:19:12 PM »
here is the drawing from the shop manual.
Offline GammaFlat
« Reply #4 on: March 22, 2009, 07:25:16 AM »
Let me know if I "missed the mark".
K6
K7
  • 1981 CB900 Custom
    • Free Wild
« Reply #5 on: March 22, 2009, 09:19:19 AM »
Spot on pics! Thanks so much. That did the trick. I learned that when I sprung it when I disassembled it the spring must have unwound at least one extra wrap and without that tension the choke wouldn't snap back to open.  ;D
Now I need to replace one little rubber tube and I can put the carbs back on the bike. Ride safe.
