Author Topic: Getting carbs in and out  (Read 1053 times)
Offline TomL
« on: March 23, 2009, 12:21:31 PM »
What is the easiest way to take out and put in the carbs on a 350F?  I got them out by monkeying with the plastic airbox and popping out all the rubber boots.  There has got to be an easy way without taking apart the whole bike.  Any ideas?
Offline tomkimberly
Re: Getting carbs in and out
« Reply #1 on: March 23, 2009, 04:50:12 PM »
Does this help?
Tom
Offline TomL
« Reply #2 on: March 23, 2009, 04:54:24 PM »
I see what you're doing there.  Good idea!!
Offline 750goes
  • it will live
« Reply #3 on: March 23, 2009, 07:17:08 PM »
another hint - use another ratchet strap to push the carbs into the carb-head connectors....they go on nice and steady as well - heat the connectors with a hair dryer for a few minutes makes them soft enough - also smear inside the rubbers with a bit of vaseline or your choice of lubricant...
Offline gregk
« Reply #4 on: March 24, 2009, 08:09:20 AM »
Tom
take the air intake off the bike completely.  this is the part that fits from the carbs into the filter housing.  There is an oval tin piece that fits from the intake runner into the filter box.  You can pry this piece into the filter box after you have removed the paper element.
then pulling the carbs and replacing them is easier, not easy but easier.
good luck
greg
I don't want it to go like a motorcycle, I want it to go like a rocket!
« Reply #5 on: March 24, 2009, 09:42:33 AM »
another hint - heat the connectors with a hair dryer for a few minutes makes them soft enough - also smear inside the rubbers with a bit of vaseline or your choice of lubricant...
KY Warming takes care of both birds....lol
sorry
:P
as GREG stated, take off/out the airbox.
and while its out, check it for leaks and seal if needed.
