Author Topic: Replacing brass parts in petcock. (CB500, some 550's and 750's.)  (Read 6808 times)
Offline papp101
The brass bits on my petcock were done for! It had a brass drain tube that was completely cracked, and a missing brass fuel line nipple/barb. So I made a set.
Hopefully if anyone ever has a similar situation, they can just jump in a try things like this as brass is easy to work with and fairly cheap.
7/16" brass tube and 1/4" brass barbed compressor fitting. Both tapered and tapped in with a small hammer.
Re: Replacing brass parts in petcock. (CB500, some 550's and 750's.)
« Reply #1 on: March 24, 2009, 12:25:46 AM »
Nicely done!
Offline papp101
« Reply #2 on: March 24, 2009, 12:41:31 AM »
Thank you sir! Always willing to contribute the cheap way of doing it!
Offline hopterfixer
    • My flickr Gallery->
« Reply #3 on: March 24, 2009, 03:25:48 AM »
I did the same thing to the "main" tube in the tank, mine was split all the way down the side.  Nice work.
CU2151
« Reply #4 on: March 27, 2009, 04:46:36 PM »
This is exactly what I am needing to do!  I bought the bike without the reserve tube and without a functional speedo, so running out of gas was a very real possibility.  Thanks for the pics, it will really help out! ;D
CU2151
« Reply #5 on: March 27, 2009, 04:56:07 PM »
I've heard of soldering the reserve tube in place...have you heard of this?  Is it easier to just taper it and tap it in with a hammer?  Should I use JB Weld or anything else to ensure seal?
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: March 27, 2009, 05:30:43 PM »
Well done!  I like your lathe ;)
Maybe some Red Loctite would be good here?
mystic_1
- John Augustus Shedd
masonryman
« Reply #7 on: March 27, 2009, 06:38:00 PM »
 My vote for creative use of tools. My calipers only have a round dial with little numbers, not the BIG digy numbers, I guess I'll have to find another way...
Nice work with what you have
Mark
Offline riotmachine
  • Live Forever or Die Trying
« Reply #8 on: July 23, 2009, 12:48:59 AM »
what size are the bolts that attach the petcock to the tank? i'm missing those from my rebuild kit.
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« Reply #9 on: December 31, 2013, 08:30:41 AM »
How did you taper the tube? Also, where can I get the tubing ? Home Depot ?
Offline robdrobd
  • Who? Me?
« Reply #10 on: December 31, 2013, 08:31:21 AM »
Sorry, I responded to a four year old post . :)
« Reply #11 on: December 31, 2013, 08:47:08 AM »
I would try a plumbing supply store
« Reply #12 on: December 31, 2013, 08:56:41 AM »
I know it is M6 on my CB750.
