Is it just me or are the cam chains on a 550 one link too short?!?!
I just finished the final torque on the head of my '77 550K US model, stock and am now installing/wrestling/cursing my cam chain! I've read my Haynes manual which, IMHO, explains the process in VERY simplistic terms (SLIP the camshaft through the sprocket and chain, SET the camshaft into it's bearings, ALIGN the T mark of cylinders 1.4, ROTATE the camshaft to proper alignment, HOOK the chain on the sprocket, FIT the sprocket onto its spigot, have a cup of tea!)
I'm sure in some form, this procedure works. But what are the details? I know that the camshaft can only go in from the right and that the cam chain can't be fitted to the sprocket during insertion. Should the shaft go through the sprocket first or should the chain be on the 3.4 side of the sprocket? Any trick to getting enough slack to HOOK the chain onto the sprocket while maintaining alignments? I have the chain tensioner retracted as much as possible, but still, the chain seems a link too short! Is the secret to use the "Mickey Mouse" ears cut out of the center of the sprocket maybe?
I'd appreciate any advice y'all can give me.
