Author Topic: RPM comes down slow  (Read 6190 times)
Offline friedfish80
RPM comes down slow
« on: March 24, 2009, 11:57:24 AM »
76 CB750F with 78K motor
Work done in past 100 miles: checked timing, set valves, set cam chain tention, oil changed, set idle air screws.
Running pods that have been clear coated to reduce air intake and straight piped threw 4-1.
Ordered my morgan carb tune today. When I rev the bike around 3K and above it takes some time for the RPM to drop back to idle. Also sometimes it comes down to around 2K and idles there. I got a strong feeling I that i just need a sync to get it all dialed in.
Am i at least on the right track?
Am i forgetting anything?
Offline BlackMax
Re: RPM comes down slow
« Reply #1 on: March 24, 2009, 12:31:57 PM »
could be the cable.   I've had a sticky cable before.   However, I usually equate a resistance to idle down to a mixture that may be too lean.
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline Inigo Montoya
« Reply #2 on: March 24, 2009, 01:10:23 PM »
Try spraying carb cleaner around the airbox and carb rubbers to see if the rpm changes. If it does, air leak.
Offline friedfish80
« Reply #3 on: March 24, 2009, 02:09:12 PM »
New cables last year.
Offline Laminar
  • Retsam
« Reply #4 on: March 24, 2009, 02:22:09 PM »
If you physically twist the throttle grip further "off," do the RPMs go down? My Nighthawk had good cables, but they weren't adjusted perfectly, so at times the cables would hold the throttle open just a tiny bit.
Offline friedfish80
« Reply #5 on: March 24, 2009, 03:11:56 PM »
Ok I know that my cables aren't fully adjusted properly. But no twisting back to off dosent help.
Also when I'm ridding and at speed I pull in the clutch it will rev up about 200 RPM if not more.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: March 24, 2009, 05:27:33 PM »
CV carbs?  If so then too much air intake restriction can cause this.  Remove pods, problem remains?
mystic_1
- John Augustus Shedd
Offline friedfish80
« Reply #7 on: March 24, 2009, 05:33:16 PM »
mystic_1
had the same issue when they werent clear coated.
Offline friedfish80
« Reply #8 on: March 24, 2009, 05:46:16 PM »
tried that and dident noticed any change in the rpm
Offline friedfish80
« Reply #9 on: April 01, 2009, 09:13:27 AM »
Ok got the morgan carb tune and went and got them sync this morning. bike runs alot better. But as i rev it still comeing down slow. I know that the throttle cables are loose. I cant seem to get the cables tight.
Any help?????
Please????
jumpjg
« Reply #10 on: April 01, 2009, 09:51:28 AM »
Might want to check the operation of your ignition advance mechanism. If the springs are sacked out and/or there is friction in the mechanism, it could stay advanced and hold your idle high.
Offline UnCrash
  • Pass
    • My Blog
« Reply #11 on: April 01, 2009, 10:10:19 AM »
I know on my 76K that after the bike is warmed up the RPM's come down slow if I haven't pushed my choke completely off.
Offline friedfish80
« Reply #12 on: April 01, 2009, 11:23:50 AM »
barely ever use the choke. bike starts on one kick cold everytime.
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
« Reply #13 on: April 01, 2009, 12:10:14 PM »
Which carbs do you have???,(1) I would suspect the mix is lean, (2) Is one of the slides a little bit sticky in the carb throat,(3) Do you have an accel' pump,Is it weeping a tiny bit  of gas,    Some things I have encountered over the years,   Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Offline friedfish80
« Reply #14 on: April 01, 2009, 12:21:11 PM »
keihin carbs.
Perhaps a lean condition. Now that i got this all set "corectly" it will not fire on its own without starting fluid when cold.
Offline Head
    • My Bikes
« Reply #15 on: April 01, 2009, 12:24:39 PM »
Recheck the slow jets to make sure they are clear?   Head
Offline friedfish80
« Reply #16 on: April 01, 2009, 12:56:54 PM »
yea was thinking the same thing too. Thats the one thing i havent done yet is rip off the carbs and checked them.
Offline UnCrash
  • Pass
    • My Blog
« Reply #17 on: April 01, 2009, 01:14:02 PM »
Even when it's cold out?
That is quite unusual.
Offline friedfish80
« Reply #18 on: April 01, 2009, 02:06:48 PM »
well bought the bike middle of the summer last year. First bike and never started the bike under 50. untill now
Offline friedfish80
« Reply #19 on: April 03, 2009, 09:22:06 PM »
ok ripped off the carbs and replaced the bowls with clean ones i had. The old ones had some varnish on the bottom of them. Replaced the slow and the main jets. The slow jet on carb #1 was completely plugged. i just got them back on and ill run the lines and redo the cables tomorrow after work. hopefully it will fix my issue.
This is the rag on my was on my toolbox what i used to soak up the carb cleaner. It was clean when i started.
cherry bomb
« Reply #20 on: April 03, 2009, 10:03:10 PM »
ive been having the same issue with my 77F...originally the #2,3 were totally blocked so #1,4 were doing all the work cleaned them good and it still had the problem so I gave them a good bench sync and changed the mains and set the idle screws to the recommended "stock" position...I have pods and straight pipes too so I went with 115's on the main...it seems to work well if I have the throttle stop set really really low...but the second I adjust the throttle stop the RPM comes right on up and holds about 2k I just adjust the throttle stop back down and down she comes...I need to get a good gauge sync on 'er just to busy right now...sounds to me like you are on the right track to get it taken care of...just eliminate things one at a time.
ev0lution7
« Reply #21 on: April 04, 2009, 07:08:24 AM »
condition of hanging RPM:
advanced timming
mixture off
idle screw off
those are just about it if you have checked your cables those are the 3 things that will make the rpm hang...
Offline friedfish80
« Reply #22 on: April 04, 2009, 07:15:07 AM »
timeing checks out. All idle screws are out 1 full turn. How would I know about the mixture?
Also I never cleaned the idle  screws. Should I pull them out and shoot some carb clean down there?
Offline friedfish80
« Reply #23 on: April 04, 2009, 04:27:37 PM »
Got the carbs plumed up and cables on. I dont know what told me to check it out. But got opened up the R handlebar control and took a look at the cables. Turns out that the PUSH cable was broken. Thankfully a buddy of mine had given be a bunch of parts when he locked up the motor on his chopper. Ran the new cable and WOW what a diffrence. Bike starts cold on 1 kick without the choke and wants to idle now. As opposed to haveing to keep it reved till it warms up. Bike runs strong and the RPM acts the way it should.
Thanks for all the help to everyone.
Now i got to fix the leaky carb bowl on carb #3. I guess it never ends.
