Author Topic: stripping and resealing tank. por-15 Q's and can I use radiator sealer?  (Read 1406 times)
Offline cormier1989
  • [URL=http://img41.imageshack.us/i/69316472.png/][I
So as I type this my tank is on day two of sitting in its bath of muriatic acid and water to remove the rust and paint. There is a pin hole on the side of the tank and I have yet to see the bottom. All I know is that there is at least one hole on the bottom of the tank which was sealed a while ago with what looks like calk... It looks like the inside of the tank has an old kreem liner and from other threads I dont want to go with kreem. so how do you use por-15 in a tank on the website it seems to be advertised as a paint on thing. My other question is, can I seal the tank with the stuff they use to seal radiators? I plan on using an epoxy for gas tanks to seal up the holes on the outside and then doing a good seal on the inside.
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
Radiator sealants, if you're referring to what I think you are, require heating and cooling cycles of the engine's cooling system to work.
And as far as POR-15 goes, I used it and it has been holding up. They have kits for bike tanks specifically and it's pretty straight forward: http://www.por15.com/CYCLE-TANK-REPAIR-KIT/productinfo/CTRK/
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline cormier1989
thanks, i think ill order some por 15 then.
