'77 550K US Model
I'm having a REAL struggle fitting the head cover over the camshaft. When I put the head cover on and tighten the hold down bolts to finger tight, I can turn the engine pretty easily with the kick arm. The trouble comes in when I torque the cover to spec. The engine becomes bound up TIGHT! can't move it a bit. Not like it rotates to a point and stops, it's just plain stuck. If I relax the bolts, she spins normally again.
I'm just finishing a top end rebuild. The head cover, camshaft, rockers, valves all are original and unmachined. There is a new cam chain in her now. There was no binding problem before I took her apart. There was a boat load of silicon form-a-gasket between the head and head cover though (yes, a foreshadowing statement for all you literature buffs!).
I've inspected the camshaft & bearing surfaces for any foreign matter that might be causing it to bind, but they are all clean and coated with assembly lube. The new O-ring for the cover is seating nicely so that can't be it. Frustrating!
I got the idea to put a strip of PlastiGuage on the tops of the camshaft bearing surfaces and torque her down to see if/which bearing is binding. I also put a bead of plumber's putty over the cam chain to see if maybe the chain was contacting the cover. When I removed the cover, I got a bit of a surprise. Maybe someone here can help me figure this one out.
First, the plumbers putty was undisturbed. The chain was not binding to the top of the cover. One PlastiGuage fell off (outside left bearing), so no data on that surface. The other three had an unusual but consistent pattern. The left end of the PlastiGuage was pristine. The right end was smashed to the extreme. I used GREEN PlastiGuage, so the clearance on the left of each surface was .003 or more and the right was .001, possibly less. This was consistent on all three bearing surfaces.
Could I possibly have a warped cover? I wonder if this explains why a PO gooped up the mating surface with all that silicone.
Any advice or thoughts would be greatly appreciated!
