Author Topic: 1979 Suzuki gs550l shifting trouble  (Read 1061 times)
Offline torrinh
  • If you don't ride in the rain, you don't ride.
« on: March 25, 2009, 11:00:17 PM »
My brother asked me to post this:
When he's riding his gs550 and needs to shift up, he has to tap down first, then he can lift up to upshift. Opposite when he needs to downshift, he has to lift gently up on the shift pedal, then he can press down, and shift smoothly. If he doesn't go through these steps, he can't shift at all. What's up? Bent selector?
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline Gordon
  • 750K1, 550K2
Re: 1979 Suzuki gs550l shifting trouble
« Reply #1 on: March 25, 2009, 11:02:12 PM »
I'd start with making sure the clutch is adjusted properly.  If that's it, then problem solved.  If not, then move on to more difficult to diagnose possibilities.
Also, I don't know about the GS550 specifically, but it should be pretty easy to take the shifter cover off to get a look at the components to make sure everything's working properly and see if anything's broken.  There may be a missing or broken spring in there that's supposed to return the shift lever to it's resting position.
« Last Edit: March 25, 2009, 11:07:04 PM by Gordon »
« Reply #2 on: March 26, 2009, 07:25:09 AM »
Sounds like the pedal return spring to me
