Author Topic: Ready for restart....1 final oil pump question  (Read 1005 times)
Offline greenjeans
  • 1972 CB750K2
« on: March 26, 2009, 07:06:36 AM »
72 Cb750K
Hoping to start her up after nearly 6 months of cleaning, painting and prepping tomorrow and realized I haven't primed the oil pump.  I've read through several posts and have found some conflicting info.
The engine hasn't been rebuilt, but during clean up etc I did take off the oil pan and pump & screen and clean them.  At the moment, there is no oil in the bike.
So, my plan is to add oil to the tank, add a 1/2 quart or so through the tappet covers & put a bit in the smaller oil galley plug at near the points.  Remove spark plugs
and kick her over a few times before hooking up the battery & plugs....
Should this do the trick ?  Or, will I have to drop the oil pan ?   I don't have an oil pressure guage, but am considering adding one.
Offline City Boy
Re: Ready for restart....1 final oil pump question
« Reply #1 on: March 26, 2009, 07:11:04 AM »
Your plan sounds fine greenjeans.Be ready to top off tank to correct level shortly after start as tank level will drop quickly.  Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline I Zombie
« Reply #2 on: March 26, 2009, 07:21:51 AM »
I did the same thing forget to prime the pump.
I tried kicken it over to prime it, but didn't notice any oil level chage till I used the starter button. I did spray the cylinders with WD40 first
78 CB750K
WHALEMAN
« Reply #3 on: March 26, 2009, 07:30:24 AM »
With the plugs out and kicking 20-30 times fast I can build up to 35 PSI on my pressure gauge for maybe 20 seconds that let's me feel that the bearings have some oil. Dan
