Author Topic: Bouncy Headlight  (Read 1252 times)
Offline DammitDan
  • Prodigal Son
  • It lives!
Bouncy Headlight
« on: October 19, 2005, 09:22:27 PM »
My headlight seems to follow every bump in the road...  It seems that I'm missing a piece somewhere, because there's about a 2 inch space between the top of the ears shank and the bottom of the upper triple tree.
I've got a little rubber piece that LOOKs like it should fit down between the fork and the shank, but it won't stay put.  Anyone got a diagram or something?  God knows I have spare parts for just about 2 full bikes... I should be able to find the actual part in my basement if I knew what I was looking for!
CB750K4
eldar
Re: Bouncy Headlight
« Reply #1 on: October 19, 2005, 09:56:59 PM »
You will always have this problem but using thick rubber spacers between the mounting ears and the light will help with this. You could I suppose figure out a way to hard mount once the light is aimed.
Offline hymodyne
« Reply #2 on: October 20, 2005, 04:26:03 AM »
that prompts a question:
where should the light be aimed?  (don't anyone say forward, either) My light seems to be at the end of its downward travel at about the same time it shines a spot directly ahead at a wall. This makes it illuminate the ground about 7-10 ft ahead of me at night. I've had no problems with visibility, with hi or lo beam, but would like to know how exactly it should be aimed.
hym
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: October 20, 2005, 04:55:53 AM »
Looked at the shop manual for my 750 and it says the beam should intersect the ground 50m/164 ft from the bike. According to Clymer, sit the bike on the ground 15 ft from a light colored wall with someone sitting on it, and the beam center should be the same height on the wall as the center of the headlight as measured from the ground.
Offline dusterdude
« Reply #4 on: October 20, 2005, 04:57:41 AM »
damn hymy,you ruined my fun for today. ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Bodi
« Reply #5 on: October 20, 2005, 06:57:56 AM »
Screw the manual, aim it where you want the light. With a stock sealed beam I tend to shift it around quite a bit when riding. For city day/night driving it's mostly an attention-getter so cagers notice me, aimed pretty high. Putting around out of town at night I want it aimed low to show the ground directly ahead of me. Faster riding in the country at night I set the high beam to light the road ahead as far as it's effective; no point in wasting light into thin air.
H4 halogen lights and some halogen sealed beams have a very sharp cutoff on low beam, set it at the horizon with you on the bike. The high beam should be at its best angle this way too. I don't generally mess with the H4 like I do with the stock type sealed beam, except to tip it up slightly in rain to shine brighter at oncoming car drivers.
As far as bouncing goes, the pivot washers get hard or shrink or whatever over the years. There's a shoulder washer in there you can file down a little to tighten the clamp, or get/make new rubber washers or even add a shim of rubber or plastic. The headlight should be movable by hand without loosening the bolts, but rigid enough not to shift or wobble on its own.
« Last Edit: October 20, 2005, 07:00:36 AM by Bodi »
