Author Topic: Main Bearings  (Read 1506 times)
Chr1s
Main Bearings
« on: March 26, 2009, 01:52:29 PM »
What a blow! just went to order the main bearings for my 400/4 re-build and they have none left at david Silv... They are colour coded black and I need a set of 10, can anyone help?
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
Re: Main Bearings
« Reply #1 on: March 26, 2009, 03:13:40 PM »
Do they need replacing?  Do you have the originals?  I used my originals over again when I rebuilt my 750.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
Chr1s
Re: Main Bearings
« Reply #2 on: March 27, 2009, 01:31:24 AM »
mmmmmm.............. dont like the idea of that, i will have another look at them. if they turn out to be bad it f@@@@ the engine up though....and all that work......and all that money.........weep......weeep
Offline Sweep
Re: Main Bearings
« Reply #3 on: March 27, 2009, 04:12:25 AM »
Mine were very smooth to the touch with no scoring, if your's are too and they meet the tolerances in the manual you can reuse them.
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
Re: Main Bearings
« Reply #4 on: March 27, 2009, 03:10:44 PM »
Scotchbrite and Plastigage...
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline Ichiban 4
  • "Ichi"
Re: Main Bearings
« Reply #5 on: March 28, 2009, 12:36:26 AM »
Another thing you might try..
Is to check on availability of "generic" bearings/inserts.  Most of the major bearing manufacturers catalog bearings according to their specs..besides the actual engines they correspond to.
What you do is mike (using a micrometer and/or vernier caliper) the dimensions..then check with a bearing supplier to see if they have anything that matches those dimensions. Or have them mike them for you.
I haven't done that on Honda's..but found bearings for other older bikes..and auto engines that way.
I'd also do an internet search (may take some time) of all the older Honda dealerships..that have been in business since your bike was built..see if any by chance have old bearing sets tucked away in their parts department.  Main bearing sets don't take up much room.
Hope you find what you need.  Keep us posted on your results,
Ichi
Al Summers
Present: '77 550K
Re: Main Bearings
« Reply #6 on: March 28, 2009, 12:56:04 AM »
How do you know they are Black coded? If you are relying on the paint splat on the edge DONT as all the colours go black with age and heat
