So you have to pull the slide up to get at it?! Weird
would this affect starting? still can't get mine to go.
no, you dont need to pull the slide to get at it.
you can either bend a hook into a piece of wire to poke around in its hole, OR,
as a last resort, pull them out. they are press in.
BUT!!!...if you are working on clearing a clog, you need to look at the check valves first. clogs typically happen here. there is one in the bottom of the accel pump bowl under the diaphragm, and there is another at the top rim of carb bowl #2(note the small oring required around this check valve. dont lose it. replace it if its dry and flat)
the accel pump diaphragm has two mickey mouse ears. both of these need to be perfectly clean, AND the diaphragm cannot be cracked or torn for it to work properly. a new one with fresh rubber is advised. carb cleaner eats diaphragms, so be warned!
