Frustration is setting in, she is still not running. So far I have checked the compression, 120 psi, low but should run. New spark plugs. checked valve clearance. removed carbs from the engine(left the rubber on the engine) and cleaned every thing I could clean. Slow jets were plugged, was able to push Marvel Mystery Oil through the accel ports, MMO because my eyesight is very poor and I can see the red oil, new accel pump kit, set floar heights, did not need adjusting, started her uo, same story, starts OK on choke, runs on 1/2 half choke dies on no choke. No fuel through the accel ports.
Throttle cables hang up with wheel turned right, OK other wise, I can fix that. I can see that these carbs have been worked on, probably several times. I am beginning to think some of the problem is in the carb linkage, the cam not pushing the accel pump, slides seem to work OK but the running on choke has me stumped. Also the float valv on #4 leaks a full stream, has been leakie before. So here I am looking for advice and assistance. may have mentioned it before, I thought the starter was noisy. The problem is that tin can starter cover is bolted to the starter and makes a good resonator. Without the cover the starter is quiet. Any how, that's my story, got any suggestions.??
