Author Topic: Steering Stem Bearing Race - Removal Trick?  (Read 8444 times)
Offline beta1042
  • '76 CB750F
« on: March 29, 2009, 01:57:03 PM »
Is there any trick to getting off the steering stem bearing race?  Is the rubber seal salvageable or is that a lost cause?  I've got the other races out of the column.  New column races are waiting in the freezer, but the stem is proving to be elusive.
Markcb750
Re: Steering Stem Bearing Race - Removal Trick?
« Reply #1 on: March 29, 2009, 02:03:06 PM »
Search for head bearing replacements lots of good discussion here.
I beat mine off with a aluminum drift.  side to side. ruined seal, but replacement kit had new spacer and seals. (AllBalls)
Seal can be salvaged by cutting race with Dremel tool.
Some members use a bearing puller, issues with clearance around the clamp arms.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: March 29, 2009, 02:25:42 PM »
+1
Not only is this method very easy, but it also allows you to get out our aggression on the damn thing! ;D
You just cut a deep slot in the race, then put a flathead screwdriver in it, push firmly to one side, and you hear a nice, satisfying "POP!" when it breaks.
« Last Edit: March 29, 2009, 02:27:15 PM by Gordon »
Offline beta1042
  • '76 CB750F
« Reply #3 on: March 29, 2009, 02:59:07 PM »
Well I tried the punch and hammer method.  Race is off and I have a sore punch holding hand.   ;D
Bottom half of seal was damaged in one area.  Kept rotating the seal and spacer to keep the damage in one spot while using the punch on the left and right sides (since that is the only place to get almost 180 degrees between hit locations).  The ringing in my hand will stop soon right?
Oh, and I didn't have much faith in my ability to cut the race with the dremel.  Figured I might butcher up the stem.  Good point though Gordon, notch it part way and wack it good with a punch in the groove.  Next time......
« Last Edit: March 29, 2009, 03:06:46 PM by beta1042 »
Offline beta1042
  • '76 CB750F
« Reply #4 on: March 29, 2009, 03:20:06 PM »
May have celebrated too soon.  The outer diameter on the face of the new tapered bearing is larger than the one on the old ball bearing race.  How does the old salvaged seal go on now?  The bearing will wind up squeezing it against the bearing... bad right?  The upper bearing didn't have a seal.  Saw some others mentioned they didn't use a seal.  Would I be better off cutting the old one in half (separate the upper and lower sections of the seal) and use one for the upper and lower.  Modify the inner diameter to fit around the new bearing outer diameters.  Upper bearing was pretty dirty without a seal.  Thanks PO.
« Reply #5 on: March 29, 2009, 03:47:46 PM »
G'Day Mate, the OD of the bearing outer should be the same as the OEM ite, are you sure you've got the right kit? I've done a few of these and you should have plenty of space for your OEM seal, and normally you'll also need to use the fat spacer washer that comes with the kit to give you some clearance between the steering head and the bottom triple tree. Cheers, Terry. ;D
Offline beta1042
  • '76 CB750F
« Reply #6 on: March 29, 2009, 04:09:50 PM »
I've attached a picture to show the differences in the diameters I'm talking about.  It's not the outer diameter of the whole bearing, just the portion of the base of the bearing that contains the tapered rollers.
Markcb750
« Reply #7 on: March 29, 2009, 04:25:03 PM »
The seal on a tapered bearing should reach out to the steering head to seal the space that the rollers rotate in.
The original seal might not function with a tapered bearing set.
check Z1 Enterprises should only be a few bucks.
Offline Alan F.
« Reply #8 on: March 31, 2009, 03:30:02 PM »
after the 'pop' the race will easily slide from the steering neck as it's now a little larger inside diameter.  Very easy this way.
+1
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #9 on: March 31, 2009, 04:51:22 PM »
Park Tools makes a fork race puller for bicycles I use to remove them on bicycles and motorcycles, it cost around $100 and worth every penny to me.
« Reply #10 on: March 31, 2009, 04:58:53 PM »
The one i just built would be a lot cheaper than that price..
Offline 78CB750CAFE
  • I'm not really an
« Reply #11 on: March 31, 2009, 06:25:23 PM »
As a pro bicycle wrench it was worth it for me, your mileage may vary.
Offline hevykevy420
« Reply #12 on: March 31, 2009, 06:43:15 PM »
i used a dremel to cut out the race.  even if you knick the frame neck its not gonna cause the bearing to spin (unless you really butcher it)
I wasn't able to use that rubber seal with the tapered bearing installed.  it just caused the whole show to bind up with the triple installed.  i don't think its absolutely necessary.
1978 CB750K - 836 Wiseco kit, 4-1 Kerker Exhaust, Web cam (63b grind), HD valve springs, polished stuff.  Comfortable.
1975 BMW R90/6 - tight
2002 RC51 - Jardine slip ons.  Uncomfortable.
Austin, TX
Offline midnightrider
  • Out of the SOHC4 world for a while...
« Reply #13 on: December 16, 2010, 01:01:52 PM »
I used a piece of 3/4" pvc and a hammer to tap out the top race and a piece of 1" pvc to bang out the bottom race on my CB350F.
The 1" pvc is a perfect, snug fit.
1972 CB350 Four - "The Green Hornet"
http://forums.sohc4.net/index.php?topic=84975.0
I love being alive and I will be the best man I possibly can; I will take love wherever I find it and offer it to everyone who will take it... seek knowledge from those wiser and teach those who wish to learn from me.
-- Duane Allman's epitaph
Offline drones76
« Reply #14 on: December 16, 2010, 01:13:10 PM »
I just got down to mine and I could not get it to budge.  A buddy of mine works for a NASCAR team and he took it to work and returned it done and the part sandblasted.   8)
I was too nervous that I would do too much damage.  I was going to pay to have it done.  The triples on my bike are known to be brittle.
1974 Norton Commando Roadster
1980 Goldwing Interstate
1975 Kawasaki KZ400D
Looking for a SOHC-4
Offline jakec
« Reply #15 on: January 22, 2019, 09:46:05 PM »
Can anyone say what kind of tip you’re talking about using on the Dremel to cut this thing? I’m looking at mine (specifically the lower triple bearing race) and it looks pretty beefy. I was able to grab the seal out with pliers so I have a good view of the race.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Online BenelliSEI
  • 1969 cb750
« Reply #16 on: January 25, 2019, 10:12:22 AM »
Jakec....... I use a small cutting wheel on my Dremel. They start out about 1” diameter, I keep a few that are 1/2 worn down for jobs like this. Cut a thin slot into the inner race and stop before you nick any part of the tree. Then insert the cold chisel to the slot. One good hit and it will “crack” right through. This works well, because the bearing is a press fit and sitting there under pressure. The hit just let’s it go! John and.
Offline jakec
« Reply #17 on: January 25, 2019, 10:28:36 AM »
OK, thank you. I see my local hardware store has cutting wheels. I didn't realize they could cut metal.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Online pjlogue
« Reply #18 on: January 25, 2019, 11:13:05 AM »
Dremel has various wheels for cutting.  The one you want is the thin abrasive one.  Not a metal one with teeth.  The thin wheels are brittle so get a bunch and wear eye protection.
-P.
