Author Topic: front stop light switch broke.......i think  (Read 1279 times)
Offline friedfish80
« on: March 30, 2009, 06:13:19 AM »
76 CB750F with 78 K motor.
Installed my new side mount tag bracket with new trailer tail light. Now the front break dosent turn on the stop light. Rear works fine. Never had a issue prior to this that i know of. I tried to check it regularly before I would venture out for a ride. I did a search and found that if i disconect the wires from the switch on the lower triple tree and jump them, and the light comes on the switch is bad. Which is what happens on my end. Doing some looking around I have found that this is no longer available threw honda.
Am i missing something or am i now destined to search threw ebay looking for a used one?
ev0lution7
Re: front stop light switch broke.......i think
« Reply #1 on: March 30, 2009, 01:28:12 PM »
dont give up hope...
z1enterprizes has a "banjo" bolt brake switch for such a failure.. no worries just replace one of your banjo bolts with that switch and leave that old switch there just cut the terminals off so you dont accidently hook it up..
