Aloha;
Kei hin carbs and pods on a chopper (Yeah, I'm getting frustrated but not enough for $600 Mikuni solution yet) . Had 115 mains and experienced typical loss of power at 3/4 to WOT. Changed to 120 mains and retained 40 slow jets. Followed Clymer manual for synchornizing carbs and can only get 5" of vacuum. Manual says adjust to 8". With 5" vacuum, and idle adjusted, needles position is at or below the 1 thread minimum recommended by Clymer. Bike is still running rich.
I went up in jet size to get rid of power loss and it worked tip-top. Pulls like a train going uphill WOT. Now running rich (little bit of smoke at idle and revving, black sooty plugs after riding). I'm not sure where the needle position is set (bought carbs rebuilt as "stock") but am assuming that I need to raise clip to drop needles further into seat to lean out? Am I on the right track or lost going down some dark siding?
Mahalo
