Author Topic: Another 350F sync'd up with Morgan Carbtune  (Read 2386 times)
Offline fmctm1sw
« on: March 30, 2009, 05:09:21 PM »
Before and after follows.  I still have a 2/3 timing issue.  It bounces around a bit and affects idle.  It will miss at idle and almost stall out at stoplights every once in a while.  I believe the shaft is out of round a bit.  I've seen posts on it here before...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline HondanutRider
Re: Another 350F sync'd up with Morgan Carbtune
« Reply #1 on: March 31, 2009, 05:13:45 AM »
So, what was the result after doing the carb sync?  Does it run better?  If so, how?
I would be interested in knowing your experience, as I am contemplating checking my CB350F.
Offline fmctm1sw
« Reply #2 on: March 31, 2009, 03:47:53 PM »
It did my other 350F for sure.  This one still has the timing issue I mentioned but I was amazed at how much better my other one ran.  Like said in the post though, I'm going to give it a few weeks and see but initial indications are good...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
