Author Topic: not firing on all cylinders cb750k  (Read 2103 times)
murtceps1
« on: October 21, 2005, 01:41:11 AM »
Have after earlier advice replaced plugs with D8EA, tested caps and replaced with new ( res approx 5) Air pod filters are reasonably new..  I am getting spark to all plugs but cyl 1 and 3 do not fire.
It would appear that I have a carb problem. I have set float levels to those set out in manual and have removed and cleaned all jets. I have been told that the pod air cleaners will make my carbies run richer ?. I have another set of good carbies that I got from a cb500 that according to what I can compare from the manuals are set up pretty much the same but the main jets drop from 120 to 100. Could I just switch carbies and see what happens.
Some advice on how to sync carbies would be appreciated. I know that this all a bit long winded but there just seem to be so many variables with bikes and I am trying to learn as I go, frustrated or not the motor mech is my admission of failure . ???
Offline oldbiker
  • I HATE RAIN
Re: not firing on all cylinders cb750k
« Reply #1 on: October 21, 2005, 02:00:21 AM »
Pod fi;lters make the motor run weaker so maybe one step up in jet size is needed.
murtceps1
« Reply #2 on: October 21, 2005, 02:47:39 AM »
Thanks, the plugs are black and sooty I thought that meant the carbs were running rich.
This is driving me crazy
Offline oldbiker
  • I HATE RAIN
« Reply #3 on: October 21, 2005, 04:18:10 AM »
Black and sooty does mean rich. Are the pods clean?
Offline dusterdude
« Reply #4 on: October 21, 2005, 04:56:08 AM »
since 1 and 3 are on the same coil,how bout a weak spark.i would check the coil and wires and also look at the points and condenser for 1 and 3 too
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline my78k
« Reply #5 on: October 21, 2005, 05:12:20 AM »
Wait a sec...I thought 1 and 4 were together and 2-3 were on the other side???
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: October 21, 2005, 05:21:45 AM »
You are correct.  1 & 4 are on one coil/point set, and 2 & 3 are on the other.  If the problem is with 1 & 3, then chances are it's not an ignition problem.
murtceps1
« Reply #7 on: October 21, 2005, 06:04:44 AM »
The pods look clean but I have had to use aerostart to get the bike firing maybe by spraying onto pods I have clogged them  in some way. Any suggestions on my carbie swap or reducing the size of my main jets . Many thanks
LeoLegendATL
« Reply #8 on: October 21, 2005, 06:14:06 AM »
you might have fouled your plugs, same thing happend to me, try a different plug in 1 and 3.
Offline Dennis
« Reply #9 on: October 21, 2005, 06:34:54 AM »
CB500 carbs on a 750  --- DON"T DO IT!!
Not even close to fitting.
Offline dusterdude
« Reply #10 on: October 21, 2005, 06:36:40 AM »
duh :(
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
eldar
« Reply #11 on: October 21, 2005, 08:06:54 AM »
You would be running way rich if you have pods on and have sooty plugs. Reset your float height and make sure your jets are clean. The 120s are probably ok but the low speed mix is off and you may need to change the clip height on the needle. Raise the clip which will drop the needle futher into the main jet which will lean out the mix some.
murtceps1
« Reply #12 on: October 22, 2005, 05:46:57 AM »
low speed mix ? , sorry I am only a novice. please explain
« Reply #13 on: October 22, 2005, 11:56:57 AM »
CB550 carbs are 22mm bore and CB750 are 28mm bore.  The rubber couplers are not interchangeable. And, would require special adapters or something creative to effect a seal between the smaller carbs and the larger couplers.  Re-jetting the 550 carbs to compensate for the increased air velocity required of the larger motor will be way more challenging than correcting the jetting in your current carbs.  Not sure, but I think the carb spacing is different, too.
I think we "talked" about this bike before.  It's the chop, right?  Do you know if the carbs are in stock form from the donor bike?  Or, has someone already twiddled with the innards?
Are you reading the correct part of the plug?
See:   http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
for what plugs should look like and to be sure your plugs have the center electrode insulator sooty.
Sooty plugs, regardless of how new, can become carbon fouled and fail to fire.  Instead of jumping the spark gap, the energy travels through the soot (carbon) built up on the center electrode insulator of the plug.  Sometimes you'll see a tiny bit of spark at the electrode only. But, it is not bridging the spark gap, and can cause failure to fire the cylinder.
Let's review basics.  The cylinder needs compression, spark correctly timed, and a reasonable fuel air ratio, for the cylinder to produce a power stroke.  For discussion, let's assume you do have correct spark.  Before you can jump squarely on the carbs as the sole culprit of misfire, wouldn't knowing the results of a compression test be helpful.  I mean, who wants to fiddle with carbs, if you have a valve problem?
Ok, if the compression is even across all 4 cylinders, and spark and timing are good, then those four beastie carbs are gonna be threatened with the pointy end of a screw driver.  The shotgun approach of replacing the entire carb assembly only has a chance of success if you have the same type on hand and know they are jetted to match your engine's fuel mixture requirements.  Otherwise, you'll be fixing the same problem (or a different one) on another set of carbs.
Carbs are misunderstood by many people, I think.  Most of the SOHC4s use carbs that have mechanically linked slides, operated directly from the twist grip.   (CV carbs have slides controlled by engine demand, not operator demand.)  So, while tuning your carbs, temporarily mark your twist grip, so you have a reference for the slide position you are selecting for the bike during operation.  Why?
Let's review how fuel is mixed with the air delivered to the engine.  Let's start with the main jet.  This is located near the bottom of the float bowls on the carb.  Its orifice size must be large enough to provide the fuel needed for the engine at wide open throttle conditions.  Since we need engine speeds lower than max RPM, we position the twist grip and the slides to restrict the amount of air going to the engine.  But, less air also needs less fuel for a proper mixture, so attached to the slides is a needle valve, tapered to gradually diminish fuel flow as the slides are lowered.  The needle valve is fed by the main jet.  The needles further restrict the rate of flow from that source.  For these carbs, the throttle valve (slides) and needle jet combination, effectively control the fuel mix between 3/4 and 1/8 throttle positions.  Below 1/8 throttle positions, the throttle valve, can’t efficiently atomize the fuel for smooth operation.  So, another slow speed circuit is present in the carb for these throttle settings, which meter fuel independent of the slide needle and main supply.  This circuit gets fuel from the float bowl, too.  It’s the slow jet, with a tiny orifice, usually located higher in the bowl so as to reduce sediment clogging.  This jet along with either an air bleed screw or an Idle Mixture Screw, controls the fuel air mix when the sides are nearly closed and it’s needle is mostly shutting off fuel from the main jet.
Each metering circuit dominates the fuel mix relative to the throttle position.  But, none are totally isolated at any throttle position.  To some extent changing one will effect operation at other throttle settings.
So, with this understanding, and knowing that your plugs are sooty, tells us that the carbs are running rich.  But, do we know if this is at all throttle positions?  Do we change all the metering devices?  Or, just the one we are dominantly operating on?  A little more information is needed.  If it is only midrange operation, perhaps lowering the needles on the slides a clip position may reduce the mixture over the 1/8 to 3/4 throttle positions to stop fouling plugs?
But, wait there’s more.  Both the slow circuit and the main/needle circuit have emulsion tubes.  What these do is premix air with the fuel prior to release into the carb bore.  There are two air jets near the inlet of the carb bore, normally a drilled restrictor hole in the casting.  Also, the emulsion tubes have cross-drilled holes that can vary in number and hole size to effect the premix of air into the fuel, and the ultimate fuel mixture delivered to the engine.  An engine that is running too rich may have the emulsion tubes or air circuit clogged.
A few words about jet flow.  Yes size matters, but also the pressure differential.   A given orifice size will flow a given amount of fluid for a set difference in pressure from one side of it to the other.  Increase the pressure differential and/or the orifice size, and more fluid will flow. (Given the same viscosity fluid.)  The carburetor uses atmospheric pressure to push fuel through its jets.  The float bowl reservoir is vented to the atmosphere, and this pushes the fuel in bowl through the jets it supplies.
The running engine lowers the atmospheric pressure in the carb bore. The resulting difference in pressure forces fuel through the jet orifices.
So what?
Well, if you change the pressure in the carb bore by closing the choke butterflies at the entrance to the carb, more fuel flows through the jets and into the engine because you are isolating a source of atmospheric pressure at the carb entrance.  A similar, but not as drastic effect occurs with restrictions in the air filter.  A carburetor ideally balanced for correct fuel mixture given a specific restriction at the carb entrance will go either rich or lean, given an increase or decrease in restriction offered by the air filter.
Oh yeah, you asked about synchronization.  This is done so each carb slide is positioned in the same place relative to the all the others.  Some where in the runner between the carb and the cylinder head is a screw plug.  This screw is removed and a fitting is placed there and four manometers are temporarily attached to the fittings.  The engine is run and the slide openings are adjusted so each of the manometers read the same vacuum pressure for all cylinders.  I like to do this at idle speeds where the slide openings are very small and minute differences in slide position show up nicely on the manometers.
Ready to tackle those carbs now?
« Last Edit: October 22, 2005, 05:44:09 PM by TwoTired »
