Author Topic: 1977 CB550F full rebuild  (Read 1540 times)
kabuki
« on: April 01, 2009, 06:19:03 PM »
Hi all,
This project started when I found this bike for $700 in decent running shape. I've been pretty interested in doing a cafe racer for a while, so I thought I'd get started. The original plan was to clean up the tank, mold a new rear clip, and some fresh paint.
The ever present head cyl oil leak was present, but since the compression was all pretty close, albeit low (110 psi), it didn't necessitate a rebuild.
Basically a friend convinced me that I should re paint the frame too, and once things started coming off, nothing short of a full restore will do now.
I've been getting lots of tips and info from this forum, and I thought I'd post my progress so that everyone can see what's going on, and offer any advice.
Cheers
Jon
Bringing it home.
Pulled the gauges apart.
This is about the point where I decided to pull everything off (I love a good project).
Polishing the carb tops.
Before and after polishing the fork legs.
A mock-up of the new gauges.
Engine out.
Relocating the battery.
Polished the front caliper.
I decided to make sure everything was okay inside the engine since things had already come this far.
Cases split.
That's about where things are at so far. I'll keep posting updates.
mr g 400/4
Re: 1977 CB550F full rebuild
« Reply #1 on: April 01, 2009, 07:10:33 PM »
Nice work. Its horrible when the "only a clean up" goes a bit bigger.
My 400F was only going to get a clean up, but now its getting a little more apart and getting a lot more expensive!
Good luck with it.
Offline fastbroshi
  • Puppet
« Reply #2 on: April 01, 2009, 07:16:04 PM »
Let me know if you want to get rid of that exhaust.
Just call me Timmaaaaay!!!
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #3 on: April 01, 2009, 07:47:35 PM »
Nice polishing work. Having done some restoration before it's so tempting not to go that route once some bolts start getting turned. Post more progress pics as you go.
1974 CB550
Forever West
