Poll
Can this airplane lift off?
yes
no
Author Topic: Can this airplane lift off?  (Read 31181 times)
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
Re: Can this airplane lift off?
« Reply #325 on: April 08, 2009, 04:24:58 AM »
Well, I beg to differ.
 I my opinion, the fault in Gordon thinking lies in fact that "propeller tows the plane through the air". Yes it does, but plane flies not because it is being towed, but because the air goes around the wings, which in turn generate lift.
Now, the propeller may turn as fast as it like, creating as much trust as it like, but UNLESS the air will start flowing around WHOLE wings the plane will NOT take off.
Of course a bit of air may go around the base of wings, but lift so generated will be waaay to small..
So, sorry, but unless you could direct somehow the stream of air to go over the WHOLE wingspan, it won't fly.
Imagine this - take a small model of a plane and direct on it narrow stream of air, like from hair-dryer, directly on its nose. It will stay put. Now, take a big fan, that covers the wingspan - the model will lift....
And THAT folks is all there is to it.... or, Dukie is right, Gordon is wrong... If you don't believe, take a model and try... The Myhtbusters AS USUAL take a lot of liberties with conditions. This plane on the movie, was moving forward.
I just can't imagine that so many of you don't realize why do the planes fly... because that's why - because of the lift created by the airflow around the profile of the wing... the whole wing, BTW....
« Last Edit: April 08, 2009, 04:37:22 AM by Buber »
Welcome to my mountains!
Mountain Chalets
Offline mystic_1
  • 1970 CB750K
« Reply #326 on: April 08, 2009, 04:44:15 AM »
Buber, re-read Gordon's post.
the plane will still move forward through the air regardless of what the conveyor belt runway beneath it is doing.
Once the plane is moving forward through the air, air will be passing over the entire wing surface and the plane will therefore take off.
The air isn't moving over the wings due to being impeled by the propeller, it's moving over the wings due to the fact that the plane is moving forward through the air.
We know this works because this is how plane actually fly in the real world.  Their forward motion results in air moving over the wings which generates lift.
mystic_1
- John Augustus Shedd
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #327 on: April 08, 2009, 04:53:44 AM »
See http://hyperphysics.phy-astr.gsu.edu/hbase/pber.html and scroll down to airfoils. It's a pretty good illustration.
Offline Buber
« Reply #328 on: April 08, 2009, 05:11:15 AM »
Ok, it seems that the question posed is misunderstood.
When the runway senses the wheels moving, the runway will match the speed of the airplane's wheels,
Ok, formulated this way, plane will eventually take off.
BUT most people understand this that he conveyor is to keep the plane stationary. In such case, it won't fly.
So, maybe we should look at this question as similar to:
what is heavier? 1kg of dawn or 1kg of steel? On the first quick shout many people will say "steel", but when they analyze the questions, the answer is obvious.
So, looks like those who say "it won't fly" are falling for it, i.e. we are not reading teh question properly, but we are ASSUMING that the conveyor belt is to keep plane stationary.
A case of misunderstanding....
If the question would be...
When the runway senses the wheels moving, the runway will match the speed of the airplane's wings,
Then there's no other answer... it won't fly.
Mountain Chalets
Offline 333
  • Time for change
« Reply #329 on: April 08, 2009, 06:31:21 AM »
Ah, Grasshopper.  One thinks that Soichiro needs a good a$$ whooping for starting this thread.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Gordon
  • 750K1, 550K2
« Reply #330 on: April 08, 2009, 06:54:17 AM »
Buber,
  Go read the first 21 pages of this thread.  It's already been explained in every way humanly possible, and not just by me.  The plane will fly.  If you don't want to accept that fact, it makes no difference to me.  I'm not going to re-type all of my previous posts, but perhaps somebody else won't mind re-typing theirs.
The fact you're not understanding is that the conveyor can't match the speed of the wings, only the wheels, and since it's the wings that make the plane fly (not the wheels), the plane will take off normally.
« Last Edit: April 08, 2009, 06:56:29 AM by Gordon »
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #331 on: April 08, 2009, 08:45:06 AM »
Imagine the conveyor adjusts itself to the speed mentioned above in setup 1 plus the reading on the plane's speedometer (which measures the speed relative to the conveyor itself).
I didn't see where this new condition was stated before this post.  I checked back through several pages of the thread just to make sure.
mystic_1
It is not a new condition - it comes from how you interpret the original problem.  That is, how the conveyor senses the wheel speed, and which "speed".  Is the conveyor sensing the speed of the plane relative to the ground?  Or is it sensing that plus what the speedometer of the plane reads?  The original question does not specify and, for fun, why not consider both...
In the original scenario, there was no need to consider infinite conveyor speed as it would never occur.
In the revised scenario, infinite speed is assumed.
If we're going to start changing the scenario by adding more and more vairables (infinite speed, frictionless bearings) than the whole thread becomes even more pointless than it was to begin with.
That's been my point all along.
Let's just go ahead and presume the existance of magical fairies why will use psionic powers to keep the wheel bearings from exploding.  After all, what do you suppose is holding the bearings in the conveyor together?
mystic_1
As I said above, it has always been there.  It has not been revised.  No one is moving the goal posts.
Because this is important to the understanding of where infinity comes from, I'm going to label it in a bold font.
How the runaway-conveyor scenario works:
Setup 1:
Imagine the conveyor adjusts itself to the speed of the plane relative to the ground.  This is the scenario where the wheels rotate at twice their normal speed.
Setup 2:
Imagine the conveyor adjusts itself to the speed mentioned above in setup 1 plus the reading on the plane's speedometer (which measures the speed relative to the conveyor itself).  In this case, the conveyor quickly speeds up to infinity.
Anyway, that's where infinity comes from.
Nope, not part of the original problem statement.   I believe you are injecting "info" simply to further the thread life.
There is an airplane on a runway. The runway is like a conveyor belt, and can detect the speed of the wheels of the airplane. When the runway senses the wheels moving, the runway will match the speed of the airplane's wheels, but in the opposite direction.
I must insist, it was always a possibility.  The conveyor senses the wheels moving with respect to what?
P.S.  When I have stated "infinite conveyor," I've always meant that in terms of infinite speed, not length.  I mention this because I don't think I was clear before.
« Last Edit: April 08, 2009, 11:44:12 AM by soichiro »
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
  • Tuck
« Reply #332 on: April 08, 2009, 08:50:53 AM »
This may be a thread killer, but I'll post it anyway.  I am in no way associated with the person who wrote this.  It's just something I found.
http://blag.xkcd.com/2008/09/09/the-goddamn-airplane-on-the-goddamn-treadmill/comment-page-8/
I post this to illustrate that I have not introduced a new concept into the problem (that of the infinite-speed conveyor).
This blog entry gives away one of the paradoxes of this problem, so in a way, it's spoiling your "fun."  But then again, I still think there are other things to speculate on, for fun, that this blog entry doesn't address.
Either way, if this problem is causing trouble... then forget it.
Cheers
« Last Edit: April 08, 2009, 11:49:05 AM by soichiro »
1974 CB 750
1966 Black Bomber
  • Tuck
« Reply #333 on: April 08, 2009, 09:12:16 AM »
And I must confess a dirty little secret...
I stole the original question from another forum.  I thought it was a cute problem and it seemed to generate a LOAD of havoc over there.  I am not the author of that thread... he was smart enough to stay out of the conversation (look at his post count - it's 1).
This other forum is a "science" forum.  You may find it interesting that, according to their poll,
73 people voted,
42 (57%) said no,
31 (42%) said yes.
Compare that to our poll.  The question there was exactly the same as the one here.  It went on for 24 pages there.
http://www.thescienceforum.com/viewtopic.php?t=9419&postdays=0&postorder=asc&start=0&sid=a69a53212ad8f42841f3775aa08b32a1
1974 CB 750
1966 Black Bomber
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #334 on: April 08, 2009, 11:55:58 AM »
An aircrafts 'speedometer' is called an Air Speed Indicator, which measures the velocity of the aircraft through the air, not how fast it is moving relative to the ground.
Aircraft don't have traditional speedometers in the way we think of them.
There is no connection between how an aircraft flies and wheels it takes off on.
If, as the original problem states, the runway was a conveyor belt...bla, bla, bla, would the plane takeoff?. The problem gets people to think about how they interpret how an aircraft flies and tries to get them to decide if ultimately ground speed has anything to do with it.
The answer: It will, provided the conveyor is long enough to allow the plane to achieve FORWARD MOVEMENT THROUGH THE AIR, NOT RELATIVE TO THE CONVEYOR to an airspeed high enough for it to lift off of the conveyor. In the original problem, the runway is said to be like a conveyor belt...which says yes, it is big enough. It's a runway, not a wee conveyor like the pic I put up.
And while it is theoretically posible that the conveyor be able to reach an infinate speed as stated earlier, it never would. I already explained that part too.
Gallery at:
Offline Inigo Montoya
« Reply #335 on: April 08, 2009, 12:26:57 PM »
It does not matter what happens to the plane! My inter Galactic Spam cruiser will destroy it!!!! :D
Offline mystic_1
  • 1970 CB750K
« Reply #336 on: April 08, 2009, 01:07:01 PM »
Nowhere did the original question mention a speedometer.  There's your new factor.  Suddenly you want to introduce a speedometer and connect that to the treadmill.  Pfft.
At least you've finally admitted that you're just being a troll and trying to stir the pot on this forum.  Glad you had fun.  Please stop trolling with threads reposted from other sites now.
73 people voted,
42 (57%) said no,
31 (42%) said yes.
mystic_1
  • Tuck
« Reply #337 on: April 08, 2009, 01:30:24 PM »
73 people voted,
42 (57%) said no,
31 (42%) said yes.
mystic_1
I was not being a troll.  It's an interesting problem.  I simply copied the question from somewhere else and gave a link to the other place in case anyone else was interested in how this question fared elsewhere.
Your comment is very offensive.
And there is no need to get so defensive.  Really.
« Last Edit: April 09, 2009, 09:48:42 AM by soichiro »
1974 CB 750
1966 Black Bomber
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #338 on: April 08, 2009, 01:35:03 PM »
I found it an interesting problem, but not a difficult one, until we started dealing with theoretical physics (and absolutes like ∞ and an 'f' value of 0).
No.
Offline 333
  • Time for change
« Reply #339 on: April 08, 2009, 01:51:19 PM »
Regarding the "/the-goddamn-airplane-on-the-goddamn-treadmill/comment-page-8/" link, the best part is at the end;
All in all, it’s a lovely recipe for an internet argument, and it’s been had too many times. So let’s see if we can avoid that. I suggest posting stories about something that happened to you recently, and post nice things about other peoples’ stories. If you’re desperate to tell me that I’m wrong on the internet, don’t bother. I’ve snuck onto the plane into first class with the #5 crowd and we’re busy finding out how many cocktails they’ll serve while we’re waiting for the treadmill to start. God help us if, after the fourth round of drinks, someone brings up the two envelopes paradox.
Seems like the perfect answer to me.
I'll have champagne, thank you.
Offline mystic_1
  • 1970 CB750K
« Reply #340 on: April 08, 2009, 02:24:08 PM »
The logical inference is that you wanted to generate a LOAD of havoc over here too.
mystic_1
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #341 on: April 08, 2009, 02:34:06 PM »
This thread was not political, not religous, nor did it challenge anyones moral or ethical beliefs. It did not even cross boundries such as "honda vs harley" or "ford vs chevy".
The only havoc it caused is what the contributors to the thread allowed it to cause them.
No.
Offline mystic_1
  • 1970 CB750K
« Reply #342 on: April 08, 2009, 02:36:37 PM »
I wasn't commenting about what the result of this thread was, just about what it seems the op's goal was, which was to generate arguments over semantic interpretations of intentionally misleading questions.
mystic_1
  • Tuck
« Reply #343 on: April 08, 2009, 02:40:11 PM »
mystic_1
Perhaps I should have said 'lots of discussion.'
mystic_1
No one forced you to partake in this thread.
1974 CB 750
1966 Black Bomber
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #344 on: April 08, 2009, 02:46:12 PM »
I do get perturbed by lack of data, and would have preferred tangible values be stated, but it was still fun (though I entered late.)
No.
Offline mystic_1
  • 1970 CB750K
« Reply #345 on: April 08, 2009, 02:46:37 PM »
Just as no one forced you to post it, or to keep prodding and provoking people in the direction you wanted it to go in.
So, what now?  What's the point of this thread?
mystic_1
  • Tuck
« Reply #346 on: April 08, 2009, 03:11:57 PM »
mystic_1
If you wish to continue this, it should be done via PM.
1974 CB 750
1966 Black Bomber
masonryman
« Reply #347 on: April 08, 2009, 06:05:39 PM »
when I brought up practical application verses theory I had never seen that article.
As a tradesman I look at the practical verse theory, mostly because I have little formal education beyond HS, this is the point I was trying, unsuccessfully, to make
It was fun
peace
« Last Edit: April 08, 2009, 06:23:51 PM by masonryman »
Offline my78k
« Reply #348 on: April 08, 2009, 06:47:18 PM »
24 pages now eh???? Can you tell it is still not quite riding season???
Dennis
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #349 on: April 08, 2009, 11:40:35 PM »
And whats this with everyone throwing around my name like it will evoke some sort of madness....
I think I'm perfectly sane thank you.
And I do NOT cause trouble.
Yet.  ;D
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
