Author Topic: UNUSUAL BRAKE DISC I.D.???  (Read 1439 times)
Offline 736cc
« on: April 02, 2009, 12:48:56 PM »
These have ALOT of custom machining done to them. Don't fit a CB750 hub (too small) and has 5 bolt holes. Only clue I have is owner told me they were on an aftermarket mag wheel unknown brand. 1970's era.
  Any good guesses?
[/URL][/img]
[/URL][/img]
[/URL][/img]
Offline robe0531
Re: UNUSUAL BRAKE DISC I.D.???
« Reply #1 on: April 02, 2009, 12:55:45 PM »
maybe a lester or invader
1978 cb750k
1968 Honda ca160
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #2 on: April 02, 2009, 01:03:28 PM »
Those  look like they'd fit an airhead beemer....if you're looking to get rid of them, I'd have a happy home for 'em... ;)
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
« Reply #3 on: April 02, 2009, 03:40:55 PM »
5 bolts could be 77/78 F
Offline JLeather
« Reply #4 on: April 02, 2009, 05:20:52 PM »
Yeah, I was just gonna say they looked like they'd fit a Comstar.
« Reply #5 on: April 02, 2009, 07:33:49 PM »
They look like Mark Zero's
 Can you take a chord measurement  (c-to-c across 2 bolt holes)
Offline 736cc
« Reply #6 on: April 03, 2009, 12:29:37 PM »
11" (278mm) overall disc diameter
2 1/2" (57mm) disc center opening
1 3/4" (45mm) center distance between adjacent bolt holes
2 7/8" (73mm) center distance between every other bolt holes
Who...is Mark Zero??
« Last Edit: April 03, 2009, 01:57:53 PM by 736cc »
Offline Geeto67
  • A grumpy
« Reply #7 on: April 03, 2009, 01:56:03 PM »
How big is the overall diameter? Could be for a dyson hub like the ones Dunstall used to use for the domiracers.
Edit: 11" I think is too big for the early dyson hubs. I will look at the set I have at home and see.
Maintenance Matters Most
« Reply #8 on: April 03, 2009, 07:55:23 PM »
Mark Zero  Ent. made brakes in the70,s.
Most of the wheel makers did not.
Halsraft did for their wire wheels, so did Rickmam, but most makers of mags did not.
Offline 736cc
« Reply #9 on: April 05, 2009, 11:41:42 AM »
So can anybody determine if these fit 77/78 comstars?
Offline Ricky_Racer
« Reply #10 on: April 05, 2009, 01:15:53 PM »
Okay, I'll see if I can lend some light on these. They are by Mark-O. The fitment is custom. The last set that came up on eBay (item 180321669689 end time  Jan-24) sold for $45. I know because my sniping software was a couple seconds off and I missed the bid.
If you're going to sell them, since I could still use a set for a custom application, I'm calling dibs. PM me if you want to discuss it. Thanks. RR
« Reply #11 on: April 05, 2009, 09:14:25 PM »
A Ha !!
 I figured RR had mentioned them before..
 I think they were one of the very first custom brake discs on the market..
Offline JLeather
« Reply #12 on: April 06, 2009, 04:10:42 AM »
I'll try and make myself remember to measure a Comstar rotor when I get home unless someone beats me to it.
Offline JLeather
« Reply #13 on: April 07, 2009, 04:03:45 PM »
Ok.  A comstar rotor is as follows:
10 7/8" Outer Diameter (close enough to 11")
2.300" Disc Center Opening
1.185" Center Distance between adjacent bolt holes
Guess it's not from a Comstar.  It could be an 80's suzuki wheel, they were 5-hole rotor.
