Author Topic: Tune up weekend!  (Read 1169 times)
Offline JBMorse
    • Travel Blog
Tune up weekend!
« on: April 03, 2009, 07:03:43 AM »
Well I'm home for the weekend and plan to do all the things in the maintenance section of the manual!  I finally have all the tools including the angled feeler gauges and a spark plug wrench that will fit in the head.  Thanks everyone for your previous advice on these tools!  My plug wrench came from crc2online.com and was much cheaper than an oem but similar in style.
 When I adjust the cam chain, does the engine need to be warm or cold?  The manual says valves are adjusted cold, but doesn't specify cam chain.
I look forward to dialing the old girl in.  Riding season is here!
« Last Edit: April 03, 2009, 07:06:36 AM by JBMorse »
1971 CB500K
Offline OldSchool_IsCool
  • Really feeling like an
Re: Tune up weekend!
« Reply #1 on: April 03, 2009, 07:19:56 AM »
I don't think it matters warm or cold other than you need to stick your hand under the carbs to the back of the cylinder block.  A problem if its too hot.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #2 on: April 03, 2009, 07:54:25 AM »
what angled feeler gauges did you get? I have had trouble finding a .08mm and I need one to do my exhaust valves.
Offline JBMorse
    • Travel Blog
« Reply #3 on: April 03, 2009, 08:48:32 AM »
I got a motion pro angled feeler gauge from Z1.  At the local auto stores I couldn't find .002 and .003 angled.  I guess it's a tighter tolerance than most cars use?  Anyway, Z1 also has the size you need:
http://www.z1enterprises.com/detail.aspx?ID=2877
1971 CB500K
Offline 78CB750CAFE
  • I'm not really an
« Reply #4 on: April 03, 2009, 09:30:47 AM »
sweet, thanks.
I just ordered 2 of each :)
