Author Topic: Battery and kick start  (Read 2028 times)
Offline ozee
« on: April 03, 2009, 08:31:46 AM »
Hi,
I just bought a CB550, it is my first bike. It is running really well, but my battery won't hold a charge. The battery is brand new though. The battery was really strong when I first bought it (I killed it a bunch and had to keep restarting it), but when I got it home the battery ran out of juice when I tried to start it. Now it recharges a little but runs out of power fast, and i have ran it long enough to recharge. Has anyone had a charge problem with this bike?
Also, my kick start doesn't work? how easy/difficult/expensive would that be to fix?
Thanks
ev0lution7
Re: Battery and kick start
« Reply #1 on: April 03, 2009, 08:37:12 AM »
read the FAQ about charging issues you need a multimeter and a wire diagram... it sounds like without looking at your bike that you have either a regulator issue or a rectifier issue or bad harness plugs going from the altinator to the harness or to the above coponents.. check out the FAQ it has great wealth of info on charging problems on these bikes.
Offline ozee
« Reply #2 on: April 03, 2009, 08:46:41 AM »
ok. thanks a lot.
ev0lution7
« Reply #3 on: April 03, 2009, 01:27:06 PM »
also do a search i have posted many times on this subject and have replaced ALL the harness plugs on my bike and also put in a solid state regulator, and my own home made rectifier also check your fuse box there is prol high resistance on those old glass fuses..
http://www.oregonmotorcycleparts.com/index.html
check those guys out its were i got my stuff from and they have good prices and good shipping and NO sales tax...
Offline my78k
« Reply #4 on: April 03, 2009, 01:31:16 PM »
Don't forget you need to keep the revs up on these for them to charge at all...something around 3000 rpms and under and you are draining the battery not charging it. I think the peak charge isn't reached until around 5500 or so.
Dennis
Offline 333
  • Time for change
« Reply #5 on: April 03, 2009, 01:34:16 PM »
Also, try to keep the headlight off, if you have the option.
With some of these bikes, the kickstarter won't engage with the clutch pulled in.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
ev0lution7
« Reply #6 on: April 03, 2009, 01:35:29 PM »
actually if everything is about new and your using a solid state regulator mine will charge at about 1500 and will "maintain" below that it wont "drain" thats for sure....
Offline MJL
  • Don't listen to me, I'm no
« Reply #7 on: April 03, 2009, 02:00:25 PM »
Yeah I know 650's need to be around 1500 rpm or higher.
Offline ozee
« Reply #8 on: April 03, 2009, 02:49:29 PM »
Thanks for all your help everyone, i will let you know what happens.
