Author Topic: Marla, from 80s style street bike to ...something different  (Read 41402 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: Marla, form 80s style street bike to ...something different
« Reply #25 on: April 05, 2009, 04:52:25 pm »
but i do admire your penchant for holes... very cool.
thanks for saving a sohc from god knows what hell.
 ;D ;D
No problem, It's my sworn duty as a man.
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #26 on: April 05, 2009, 06:39:11 pm »
 ;D ;D
which one is your sworn duty as a man, saving a SOHC or the penchant for holes? ;)
  • Like a well oiled
    • Undead Asphalt
« Reply #27 on: April 05, 2009, 08:04:01 pm »
hah, the saving a sohc part.  8)
  • Like a well oiled
    • Undead Asphalt
« Reply #28 on: April 05, 2009, 09:01:53 pm »
I made this for my avatar but it's too big i guess
Offline rachet
  • '77 CB750 F2
« Reply #29 on: April 05, 2009, 09:03:14 pm »
That's cool!
But I need Tacos!  I need them or I will explode!
  • Like a well oiled
    • Undead Asphalt
« Reply #30 on: April 05, 2009, 09:17:33 pm »
I did this one to see the difference between the two swingarms.
i was bored today.
Offline martino1972
  • and still a expert welder,period...
« Reply #31 on: April 05, 2009, 11:41:40 pm »
absolutely amazing.....love it....
only thing i would be kinda worried about with the holes is your bar that holds the back brake in place...if that thing snaps due to the holes it will lock your rear wheel up,cause the braking plate can turn and tightens up the rear brake,thus locking the rear wheel....then again it's hard to judge by a picture how strong that bar is....i'm sure you know what your doing there......but the looks are awesome........might steal some of those ideas if you don't mind..(my bike is in my shop for some further mod's)..... ;D ;D ;D
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
  • Like a well oiled
    • Undead Asphalt
« Reply #32 on: April 06, 2009, 06:23:15 am »
martino-
that bar is 3/8'' 60/61 aircraft, and doesn't bend without some real muscle on it. I'm gonna do a different one though- the pattern doesn't match the one I was doing on the bike.
anybody want it?
steal all the ideas you want, it's not patented.
 just don't forget where you got em.  :D  ;D
I'm gonna try to drop the ears on the stock headlight brackets next.
need to find someone to re-chrome 'em cheap afterward.
I want them to look factory with a bit of question marks when people look at it.
Offline griff6-5-zero
  • WNY CB Crew
« Reply #33 on: April 06, 2009, 06:02:30 pm »
nice ride!
bronco7794
« Reply #34 on: April 14, 2009, 09:34:47 pm »
I have two question for you.... what is involved with the swingarm swap? and what size rear tire are you running??
thanks
Paul
  • Like a well oiled
    • Undead Asphalt
« Reply #35 on: April 14, 2009, 09:52:51 pm »
heres a link to what I did.
http://forums.sohc4.net/index.php?topic=46599.0;all
   Sort of a what not to do, in terms of bearing removal... But, you live and you learn.
the tire I'm using is a 130/90/16, but a 140 tire fits with ease too.
there's some things I didn't mention in the thread, but they were common sense. (seal replacement, and torque specs) and maybe a few others.
  • Like a well oiled
    • Undead Asphalt
« Reply #36 on: November 01, 2009, 05:14:58 pm »
update to what it looks like now and future mods
the new seat and back end lighting
http://forums.sohc4.net/index.php?topic=56057.0
« Last Edit: November 02, 2009, 07:29:58 am by Industrial Cafe »
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #37 on: November 02, 2009, 05:44:02 am »
what swing arm is that you are swapping in? what are the dimensions on it?
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #38 on: November 02, 2009, 07:15:57 am »
i dont remember, what did you end up doing with that seat?
Mark Twain - Notebook, 1894
  • Like a well oiled
    • Undead Asphalt
« Reply #39 on: November 02, 2009, 07:29:07 am »
the mono shock is on the back burner till I get all the parts together, but its a 93 CBR600f2 swingarm.
the pivot point is 9.25in wide(about 1/4 inch over stock)
it's 24 inches long overall
21.5in from the center of the pivot bolt to the axle which is about 3.5 inch stretch from stock, or 1 inch longer than what I have now
about 9 inches between the legs (where the axle is)
it's gonna be some work to fit it, but not so much that I can't deal with it
I'll shave down the mating surfaces in the pivot point
shave off all the tabs on the swingarm and add my own
fit an 18'' wheel with a big disc brake
drill and sleeve the frame to fit the 15mm pivot bolt
    (cause I'm @ 16mm right now from the DOHC one)
 modify a front fender to hug the rear tire
make rearsets with yamaha R6 foot levers, master cyl, and my own pegs and brackets.
and get a longer chain.
for the shock-
weld a clevis tab to the frame brace on the bottom for the dogbone link
and weld another clevis tab to a plate and weld that plate to the brace on the backbone under the tank.
needless to say I'll have to relocate the battery and fab up an oil tank
here's the battery I'll use.
It's 12v 190cca same as stock but sealed, thinner, and almost half as tall
 it's dimensions are 3.5'' wide X 4.5 high X 6'' long.
http://www.factoriesonline.com/ProductInfo.aspx?id=5447097
and the oil tank I'll make out of aluminum, but I haven't figured out a design yet, most likely formed to fit low and tight to the motor and swingarm area.
there may be more but I think I'm done rambling for now.
you disappeared man!  I sold it to somebody locally for 30 bucks.
« Last Edit: November 02, 2009, 07:42:52 am by Industrial Cafe »
« Reply #40 on: November 02, 2009, 09:21:08 am »
sounds good. Im in the process of looking for a monoshock swinger that is close to the stock specs or able to be modified to retain stock wheelbase numbers.  I am liking the ability to shorten the F4i swinger by grinding the welds off the end of the swing arm and shortening the fork legs to get me closer to the stock wheelbase.
VISIT OUR WEBSITE!
Facebook:
Instagram:
  • Like a well oiled
    • Undead Asphalt
« Reply #41 on: November 02, 2009, 10:29:48 am »
yeah that makes sense, I just never liked the short wheelbase.
 to me it looked out of proportion when compared to the space between the front wheel and the frame.
« Reply #42 on: November 02, 2009, 12:42:35 pm »
Do you need some shirts? I would be happy to send ya some, I have some to fit the kid too.
It's coming awesome.
shirts ya say? PM me, I'd like to know more!
and thanks
I wouldn't give this guy anything,.....He steals from the Salvation Army :D :D :D :D :D :D :D
Sam ::)
  • Like a well oiled
    • Undead Asphalt
« Reply #43 on: November 02, 2009, 03:05:10 pm »
HAHA! they wouldn't have known what they had and it would've went to someone that didn't love it like I do.
 I know, I'm psychic :D
JRK5892
« Reply #44 on: November 02, 2009, 03:32:56 pm »
wicked buildl man! i love it
Offline MJL
  • Don't listen to me, I'm no
« Reply #45 on: November 10, 2009, 02:13:05 pm »
Since the pictures don't show up, can you post a direct link to your photobucket account?
  • Like a well oiled
    • Undead Asphalt
« Reply #46 on: November 10, 2009, 03:26:31 pm »
http://photobucket.com/manchicken3
it's a cluster#$%* of pictures, so.... have fun!
the guest password is mercedes
« Last Edit: November 10, 2009, 03:39:58 pm by Industrial Cafe »
Yak
« Reply #47 on: November 11, 2009, 12:08:16 pm »
lookin' good, keep it up
(by the way, is that a Luna moth in your photobucket pictures?)
  • Like a well oiled
    • Undead Asphalt
« Reply #48 on: November 11, 2009, 02:47:44 pm »
it's a Polyphemus moth, they're all over my back porch.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #49 on: December 17, 2009, 07:15:07 pm »
How did I miss this build thread for so long.  Man... I never realized how many holes you had in your bike.  Impressive!
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
