Author Topic: 1976 cb550F  (Read 867 times)
Offline springer
  • They call me Stubby
1976 cb550F
« on: April 05, 2009, 08:49:27 AM »
Hey everyone i'm trying to check my charging with my manual if i take the power wire off my battery my bike stop running, shouldn't stay running with no battery? if i charge battery over night and go for a 100 around trip when i shut the bike off the battery is dead or down were it will not start the bike. if i kick start it will run but if i jump on it hard it not getting good power from the battery so it run's like crap, but it dose charge back up if i just ride a little and no hot dogging it any help would be great thanks
1975 cb55f
1977 cb550k
2007 suzuki gsx1300r Just a Speed Toy
and as of 1/2014 sold
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: 1976 cb550F
« Reply #1 on: April 05, 2009, 09:53:31 AM »
First, these bikes use what is referred to as a "battery ignition" not a "magneto ignition" and so the battery must be in place to complete the circuit.
Charging ok at low rpms and not at high rpms indicates a possible fault with the regulator.  The best thing to do is check the entire charging/electrical system including wiring harness connections which get dirty over time.  If you have a manual, it describes how to messure the resistance of the generator and field coils, how to test the rectifier and how to set the regulator.  Have fun.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline springer
Re: 1976 cb550F
« Reply #2 on: April 05, 2009, 02:22:39 PM »
kslrr thanks for the info i will go back to the book and check all you said later
1975 cb55f
1977 cb550k
Offline kslrr
Re: 1976 cb550F
« Reply #3 on: April 05, 2009, 02:36:27 PM »
Your very welcome. :)
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
