Author Topic: DOHC vs SOHC tach oil seal  (Read 1067 times)
Offline 736cc
« on: April 06, 2009, 11:24:15 AM »
Its been posted here that a DOHC tach seal works better on a sohc CB750 than oem. Anybody try that and have the part # ? Thank you
Re: DOHC vs SOHC tach oil seal
« Reply #1 on: April 06, 2009, 11:24:54 AM »
+1
Offline eurban
« Reply #2 on: April 06, 2009, 06:36:53 PM »
My 78 750K has had a tach seal from an early eighties DOHC in it for 4 years or so.  The seal has worked perfectly so far.  I don't have the part number off hand but go to any online parts diagram site and pull up the seal from an 80CB750 and it will be the one I used. At the time, I compared it to the a new SOHC seal and I recall it being the same ID and OD as the stock seal but with a bit stouter appearance.  Order one up and see for yourself!
Offline kenickie
« Reply #3 on: April 06, 2009, 07:10:42 PM »
91256-425-003
750K4 daily rider
550K1 (in pieces)
Offline 736cc
« Reply #4 on: April 06, 2009, 08:28:11 PM »
many thx
Offline 736cc
« Reply #5 on: April 18, 2009, 05:18:55 AM »
I installed a DOHC tach oil seal; no leaks after several days of riding. It differs slightly from a SOHC seal- the inner lip is tapered. Definate ifix to an annoying leak.
