Author Topic: What parts, if any, are exactly the same across all models?  (Read 7887 times)
Offline cb650
Re: What parts, if any, are exactly the same across all models?
« Reply #25 on: April 08, 2009, 05:53:05 PM »
You must be really bored at the new job ::).  I believe the 650 coils ar diff as we have "CDI" igy.
How about the plastic throtle tube??????   I believe we need another beer. Or a few.
fuzzybutt
« Reply #26 on: April 08, 2009, 05:58:04 PM »
throttle tube gets my vote
Offline Gordon
  • 750K1, 550K2
« Reply #27 on: April 08, 2009, 06:17:25 PM »
Tire air.
« Reply #28 on: April 08, 2009, 06:57:51 PM »
Throttle tube, not.. early had only one cable!
Stem nut & washer ,
probably steering balls, races, and washer and rubber seal.
tire stem valve core
Shock stud bolts, maybe lower bolt.
Headlight ring mount screws
Handlebar clamp bolts
petcock hose clips
« Reply #29 on: April 08, 2009, 07:00:50 PM »
Horn button
Taillight bulb
« Reply #30 on: April 08, 2009, 07:15:17 PM »
Gordon has it right: 754 is half right (the 500/550 and 350F had 1034 bulbs, 750 had 1157 when they were new). Instrument lamps and idiot light bulbs were the same.
« Reply #31 on: April 08, 2009, 09:04:48 PM »
If you mean a part that will fit on ANY Honda the answer is easy
NOTHIN
« Reply #32 on: April 08, 2009, 09:07:32 PM »
Valve stem core, would probably fit all..
« Reply #33 on: April 08, 2009, 09:25:24 PM »
Nope, used short ones on tubless rim valves
Offline 333
  • Time for change
« Reply #34 on: April 08, 2009, 09:40:56 PM »
I'm with Gordon.  Oil filters.  As a former Honda parts dude, the oil filter and associated o-rings, housing and filter bolt are the closest thing to fitting all SOHC4s.  And aside of the standardized nuts, bolts and bulbs.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #35 on: April 09, 2009, 08:52:44 AM »
Instrument lamps on the K0 750 are same as the later ones with a totally different idiot light cluster?
No.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #36 on: April 09, 2009, 09:00:02 AM »
Correct me if I'm wrong (I know someone will  ;D ), but I think the valve guides are the same on all SOHC/4's.
 Matt.
Gallery at:
Offline Soos
« Reply #37 on: April 09, 2009, 09:10:22 AM »
aside from the name.   8)
air in the tires.... :)
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Soos
« Reply #38 on: April 09, 2009, 09:15:55 AM »
 Matt.
Dunno, MReick would know better than me, but aren't cb750 valve stems a bigger diameter at the stem than cb650 stems?
cb750's are 6.5mm right?
I know cb650's are 5.5mm.
l8r
What about the headlight?
-=≡ Soos ≡=-
Offline Soos
« Reply #39 on: April 09, 2009, 09:16:51 AM »
NOTHIN
I got it.... the rider!
haha!, knew something would cross over well!
-=≡ Soos ≡=-
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #40 on: April 09, 2009, 09:20:11 AM »
kick start rubber?
certain clutch discs (but not all)
Offline heffay
« Reply #41 on: April 09, 2009, 09:29:14 AM »
i knew this would be an interesting thread... kinda like oil or octane.   ;D
Offline mystic_1
  • 1970 CB750K
« Reply #42 on: April 09, 2009, 09:47:10 AM »
kick start rubber?
BZZzzzzt!
750 K0's had a different kickstart rubber.
mystic_1
- John Augustus Shedd
Offline Soos
« Reply #43 on: April 09, 2009, 09:47:59 AM »
kick start rubber?
no kicker on the 650.
-=≡ Soos ≡=-
Offline Patrick
« Reply #44 on: April 09, 2009, 09:54:32 AM »
I've never worked on any except for 750s, but I'll play. How about the front axle?
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Soos
« Reply #45 on: April 09, 2009, 09:58:03 AM »
How about the caps that hold the axle in place?
I know the cb650 and 750 forks are different... but those I remember being somewhat similar...
it's been a while since I've seen a 750 next to a 650 though.
Wrist pins? No I be they are diff. length on the 550/650/750's
circlips? Gotta be the same. ??
(on a stock bike, no counting the delrin wrist pin buttons on some of the 836 kits)
-=≡ Soos ≡=-
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #46 on: April 09, 2009, 09:58:20 AM »
4 pages so far and nobody has mentioned...........wait for it..
Tappet cover caps..!!
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline Soos
« Reply #47 on: April 09, 2009, 09:59:29 AM »
nope the 650 has diff. ones than the 550/750's do.
WAY different.
l8r
-=≡ Soos ≡=-
Offline ttr400
« Reply #48 on: April 09, 2009, 10:08:56 AM »
Yep your right, would have to be the 650 to put a spanner in the works..
Kevin
www.ttr400.com
Offline Soos
« Reply #49 on: April 09, 2009, 10:12:01 AM »
Thats what I am here for you know~!
Glad to fulfill my job well here......
What about jets?
Mainjets.
-=≡ Soos ≡=-
