Author Topic: CB750 K0 float level  (Read 5662 times)
Offline tlbranth
« on: April 08, 2009, 04:20:50 PM »
I have a shop manual but it just says to use the float-setting guage which I don't have. Anyone know some actual measurements. The manual shows measurement from float bottom to what looks like the lip of the carb. But whatever. If I had some actual specs, I could build the guage.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Johnie
Re: CB750 K0 float level
« Reply #1 on: April 08, 2009, 04:24:59 PM »
26mm - you have to tip the carbs on their side and move them so the float just sets on the needle valve.  Then you take the measurement from the bottom of the float to the bottom of the carb body.  Below is a pic of the one I made from a floppy disk.
« Last Edit: April 08, 2009, 04:28:40 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: April 08, 2009, 04:26:51 PM »
Yes, 26mm and the concensus seem to be that the measurement is taken at the edge of the flange on the float bowl mating surface, not the gasket surface.
Use the search page and enter "float gauge", many have made their own quite easily!  Several threads have pics and instructions.
mystic_1
- John Augustus Shedd
Offline tlbranth
« Reply #3 on: April 08, 2009, 05:00:19 PM »
Thanks fellas. I'll make one of those guages straight away. To the bottom of the whole carb body eh?
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
WHALEMAN
