Author Topic: Billet blocks....who will pay...pics added 9/7/09...10/24....2/10  (Read 194991 times)
If I ask a friend to do these based on the primitive RC block who would/can pay for it? I'm thinking it could be Niksal....no sleeves! Better heat out!
« Last Edit: February 10, 2010, 06:14:06 PM by MRieck »
Re: Billet blocks....who will pay
« Reply #1 on: April 08, 2009, 08:03:33 PM »
Heres what I would like...
And may work on next winter
Either cast with liberal finning or better yet, carve out of billet.
 Major cost is the 17 inch x about 7 inch, x about 3.8 thick slab to start off.. :o
So cast is really the only somewhat  reasonable way to go, but will still come out at probably 700 plus, easily (likely) more...without pistons..
As far as I know NIKASIL is a proprietary coating (plated), put on to a certain thickness much like hardchrome.
 I think the billet with thicker fins would be just too cool..
« Reply #2 on: April 08, 2009, 08:12:49 PM »
Frank
  This guy's "hobby" machine....you can walk into. He is an industry expert. I'd love to provide these units. You are absolutely right Frank in your analysis.....well done.
fuzzybutt
« Reply #3 on: April 08, 2009, 08:52:21 PM »
i imagine we're talking about well over 1000 dollars for something like this?
  • Moderator
« Reply #4 on: April 08, 2009, 09:18:01 PM »
What a bit of one up man ship ::) ::) ::) especially if it had JMR machined into it. :D :D :D :D
The fact that there are no liners would make it much lighter but, with the ceramic bores, would the block require a different set of compression rings Mike ?
Sam. ;)
Offline BeSeeingYou
« Reply #5 on: April 08, 2009, 10:11:22 PM »
Check out Kev's Turbo at http://www.xs650.org.au/ for a project blog of someone doing this with an XS650.
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #6 on: April 08, 2009, 10:12:48 PM »
i'm following this one.  :o
for what it's worth, a small company is releasing new aluminum blocks for flat head fords. i know they have a strong following but come on now! more trivial junk: i had a dream (swear to god on this) that mike released an alum. 750 based mill. i don't go in for that power of dreaming, palm reading b.s. but this is freaky.
actually, now that i think about it, it was a whole assembly with all lessons learned on the sohc utilized.
excuse me while a try to dream about being rich.
1974 CB550K
                                  Your 1%er name
Offline Ecosse
  • Member #4139
« Reply #7 on: April 08, 2009, 10:20:42 PM »
you know, with a site like that saved, one could easily delete all their, ehem... adult material.
1974 CB550K
                                  Your 1%er name
Offline BeSeeingYou
« Reply #8 on: April 08, 2009, 10:35:15 PM »
I have found that to be true. ;D ;D ;D  It's a great website.
« Reply #9 on: April 08, 2009, 11:44:38 PM »
Hi Mike  ;D
Can I have "Griff" CNC'd into it where RC went?
ps I dug the head and the cylinders out to take to the powder coater. Gotta finish my taxes first. There goes a REAL nice engine down the drain.  :'(
Offline eurban
« Reply #10 on: April 09, 2009, 03:46:38 AM »
Thanks Mike!  I would / could pay for it but price ballpark would help here.
« Reply #11 on: April 09, 2009, 04:37:35 AM »
I'm going to talk to my friend next week about it. The block bores could be roughed out to whatever size than be sent to Millennium Plating for final boring/honing and plating. I have seen this done for FJ1200's
Offline KB02
« Reply #12 on: April 09, 2009, 05:02:36 AM »
We may need to sticky this post next to those 1000cc pistons from APE.  :)
Price may be an object, but that would be a killer combo, don't you think?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #13 on: April 09, 2009, 05:06:42 AM »
Mike,
I'll test the prototype.  ;D
Art
1972 CB750 K2 Cafe' Style
Offline PJ
« Reply #14 on: April 09, 2009, 07:09:36 AM »
Hell, I think I would like to have one just to hang on the wall as some kind of retro/modern art! ;D Even if I couldn't pop for the whole expense of assembling an engine of that size(carbs, cam, cylinder head work) now this kind of stuff will not be available later,
  • Moderator
« Reply #15 on: April 09, 2009, 05:45:11 PM »
Sticky sorted thanks to good ole uncle Bob 8) 8) 8)
Sam. ;)
  • Moderator
« Reply #16 on: April 09, 2009, 05:47:35 PM »
Mike,
Art
The prototype is being tested in November and he's got a proper tester thank you. :D :D :D :D :D :D
Sam. ;) ;D
« Reply #17 on: April 09, 2009, 06:39:22 PM »
Mike,
Art
Sam. ;) ;D
Yes me!  ;) ;) ;D ;D
cheers
Andy
  • Moderator
« Reply #18 on: April 09, 2009, 06:48:47 PM »
Sod off you Scotch twit or you won't get your panniers. :D :D :D :D :D :D
Sam. ;)
« Reply #19 on: April 09, 2009, 06:50:23 PM »
.....or you won't get your panniers. :D :D :D :D :D :D
Sam. ;)
Hopefully the come filled with Boddingtons  ;D ;D
cheers
Andy
Offline MJL
  • Don't listen to me, I'm no
« Reply #20 on: April 09, 2009, 07:11:41 PM »
I bought a couple cans of this and did not like it at all.
As for the block... I've got enough projects in my garage right now, but a big block and new pistons...  I could have that literbike I dream about. Would it wheelie?
« Reply #21 on: April 09, 2009, 08:36:56 PM »
Check out Leno's garage, he has a video of a device that laser scans a part then makes a plastic prototype [with moving parts] if the part works then you can use the program to cnc the parts for real. It made a crescent wrench and the jaw opened and closed like the original.
  • Moderator
« Reply #22 on: April 09, 2009, 08:54:05 PM »
Sam. ;)
cheers
Andy
Mike got some Boddies in last week, it will be gone by the time I get there. ;D ;D ;D ;D ;D
Sam. ;)
« Reply #23 on: April 09, 2009, 09:25:34 PM »
Don R, what should we scan?
  • Moderator
« Reply #24 on: April 09, 2009, 09:40:47 PM »
Sorry Don but that sounds a little back to front. You started by scanning the part to make a plastic one.
Why do you need a plastic one when you already have the origional one that you have just scanned ??? :-\
Sam. ;)
