Author Topic: Billet blocks....who will pay...pics added 9/7/09...10/24....2/10  (Read 239918 times)
Re: Billet blocks....who will pay
« Reply #50 on: April 15, 2009, 03:11:13 AM »
Come on Terry, we can get one each.....he may even do a group discount..... ;D
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #51 on: April 15, 2009, 06:55:57 AM »
Yes, the outside finish on the RC block is pretty rough. But that only means it'll look so much nicer once polished...
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
« Reply #52 on: April 16, 2009, 06:13:26 PM »
Well I'll be talking to my friend next week about this. I'll bring a stock CB cylinder and an RC cylinder and see what he thinks.
  Mike
Offline Ricky_Racer
« Reply #53 on: April 16, 2009, 07:31:23 PM »
Mike. Sounds like a great project. Is this cylinder streetable?  RR
Offline Big Jay
    • CBRzone
« Reply #54 on: April 16, 2009, 11:22:17 PM »
We may need to sticky this post next to those 1000cc pistons from APE.  :)
Price may be an object, but that would be a killer combo, don't you think?
The piston deal is on. Check out that thread.
« Reply #55 on: April 17, 2009, 02:10:59 AM »
Thanks Jay, ....now where's that big bore block.. ;D
« Reply #56 on: April 17, 2009, 05:04:20 AM »
Absolutely.
Offline KB02
« Reply #57 on: April 17, 2009, 05:25:09 AM »
Okay, Mike, Jay, I think we need a build thread in the Project Shop for this new engine.  ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #58 on: April 17, 2009, 05:28:54 AM »
First let me see how feasible this block will be.  ;)
Offline Big Jay
    • CBRzone
« Reply #59 on: April 17, 2009, 09:18:58 AM »
We are using a sleeve that won't break thru into the air passage on a stock block, that why no 1055s.
« Reply #60 on: April 18, 2009, 02:55:11 AM »
What size cylinders will the big block have Mike?
« Reply #61 on: April 18, 2009, 07:21:14 AM »
Any size you want is my expectation Terry. Sleeves or no sleeves....whatever somebody wants. I'd have the bore roughed out withen .040 or so with the final work done by the owner
« Reply #62 on: April 19, 2009, 02:17:53 AM »
Thanks Mike, what's the advantage of a big block? I am just going to bore out my stock block to take the 72 mm sleeves for my 1060 cc pistons and weld up where the mill breaks through the air gaps, so I'm guessing the big block will take bigger slugs again? I guess the biggest problem then is the head will let the whole plot down due to it's restrictive design, it's a pity you can't adapt a big port DOHC head on to it, now that'd really make it get up and go!;D
Offline crazypj
  • I'm brill, me
« Reply #63 on: April 19, 2009, 09:49:52 AM »
If your doing a bunch of welding you may as well weld up stud holes in crankcase and reposition studs further apart to fit DOHC top end.
 Wouldnt worry too much about breakthrough into air gaps.
In my experience, as long as base is sealed, it doesn't leak (maybe 'sweat' a bit)
 The limiting factor on boring is always stud spacing, gotta clamp it down some how.  ;D
PJ
Offline Ricky_Racer
« Reply #64 on: April 19, 2009, 10:10:07 AM »
PJ, have you or do you know of anyone who has successfully fitted a DOHC head to the SOHC motor?  Thanks!  RR
Offline crazypj
  • I'm brill, me
« Reply #65 on: April 19, 2009, 02:56:09 PM »
Sorry, I don't know anyone.
Friend of a friend in Britain was doing a Kawasaki top end on one but he would never say how or which Kawa he was using.
It was going to be about 900cc.
 I think possibly a bored GPZ750 top end on SOHC CB motor?
Why?
...because he could
PJ
« Reply #66 on: April 20, 2009, 08:40:18 PM »
Hmmmnnn, that got the old memory box thinking about something I read in a magazine many years ago about someone grafting a Boldor 900 top end onto an SOHC CB750, from memory, he actually cut the crankcase "deck" out of the rolladoor cases and welded them into a set of CB750 SOHC cases. I've got an old set of cases here, I might have to go looking for a CB900F! ;D
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #67 on: April 20, 2009, 09:38:23 PM »
in between thunder claps we'll hear terry screaming... "it's alive!!!!!"
1974 CB550K
                                  Your 1%er name
« Reply #68 on: April 25, 2009, 08:03:06 PM »
 I apologize for the delay but I have all the info and I'll post it tomorrow....I've been pretty tied up.
« Reply #69 on: April 28, 2009, 08:48:00 AM »
 Finally...some free time. This block is definitely achievable. Each block would start out as basically a 50lb piece of billet. Bore and deck height are up to the customer. Bores can be roughed out to .002/.003 undersize for piston or sleeve. Fins can be up to 1" long. A plated bore would greatly improve cooling and improve overall strength of the block. The block can have an oring groove cut into it as well. If I can get 5 orders orders price will be 1,200.00 each. Less than 5 can be done but the cost will increase.The CAD design can be sent directly to Cometic Gasket for construction of a head and base gasket.
  All design and machine work will be handled by a very well respected individual with years of private CNC operation ownership. He is an avid motorcyclist and has handled many motorcycle industry applications and other far more advanced machining projects for the automotive racing industry as well.
 Hey....the guy owns a Drysdale. ;)
  Anyway there is some info. It would take some ime to measure for the design as several case tops, cylinders and heads will have to be measured etc anybody interested please drop me a PM for further info.
  Mike
« Reply #70 on: April 28, 2009, 04:30:40 PM »
Hi Mike, if less than 5 orders is more expensive, does that mean 10 or more would be cheaper.
I would absolutely love one but $1200.00 is just a little to expensive with current exchange rates.
« Reply #71 on: April 28, 2009, 07:01:24 PM »
Mick....10 would be cheaper. For sure.
« Reply #72 on: April 28, 2009, 11:52:56 PM »
Come on all you horsepower freaks, put your hands up.... ;D
« Reply #73 on: April 29, 2009, 07:52:23 AM »
Well I cant commit on anything like that in the next few months.
But I sure am interested..
« Reply #74 on: April 29, 2009, 10:33:05 AM »
I need to get further down the road on the 900 you're doing the head for on my rebuild before I spend that cash on the 1000 for the chop. Do you have a time frame in mind?
